02-04-2014, 12:37 PM | #1 |
Wiring questions and stuff..
While redo-ing my instrument cluster, i uncovered some wiring issues behind..
Question 1) What is this "STOP LT. SW. CONN." circled in blue. The wiring connector for the steering controls is missing the wire labeled 'A', and I need to figure out where to run it to. According to this link this is a black and white wire on the other side of the connector and is likely for the horn? Question 2) Why does this orange wire travel down to the "DOME LP CONN", if it is in fact for the horn? I should add that my dome light does not work. The two wires labeled B are twisted together and not connected to anything or the fuse panel like shown in the diagram. I have feeling if i supply power to at least one that my dome will work, the other pair of orange/white appear to be intact.
1972 C20 |
02-04-2014, 01:13 PM | #2 | ||
Project Junkie! Fishing Poor!!
Re: Wiring questions and stuff..
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
02-04-2014, 01:30 PM | #3 | |
Boy a whole bunch of my responce didn't come through.
02-04-2014, 04:27 PM | #4 |
Msgt USAF Ret
The wire is black because you wouldn't be able to see it on the diagram if it was white.
The horn wire is a black and it is on the other end of the half moon connector. The orange wires near the fuse panel should be hot all the time so they probably were connected to the orange wire in the fuse panel. The white wire that goes to the headlight switch is a ground wire to ground the dome light when the knob is turned all the way to the left. Any white wires to the dome light are ground wires. You should have other white wires on the door buttons to turn on the dome. If you have a white wire on the dome light then you must not have the orange power wire.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
