steering help 65 c10
I have a 65 c10 that I converted to disks from a 73 . 73 drop spindles and used the 73 outer tie rod. Now I want to keep the 65 steering so the geometry dosent change. Ive read about the adapter sleeve but I can't find it anyone have any ideas or other options thanks
65 C10 SWB BBW ![]() |
#2 | |
![]() Quote:
HTH, Sam Last edited by luvbowties; 09-04-2013 at 12:19 AM. Reason: add link |
Re: steering help 65 c10
i did the same to my 65 and used all the newer stuff and all i had to do was drill new holes from the idler and the pitman arm bolted right on to the 65 gearbox
60-66 Nut
![]() ![]() Join Date: Mar 2007
This is what I always recommend.....except you have to use the '65 pitman arm.
Thanks went with the sleeves ill post a pic when they arrive
correct captain fab.
