04-19-2016, 07:19 AM | #1 |
intermediate steering shaft
Should the intermediate shaft slide in & out on the end that connects to the steering shaft? I know that if the plastic pins have been sheared that it will slide in the middle.
Thanks, Lynn |
04-19-2016, 07:52 AM | #2 |
Re: intermediate steering shaft
Once installed both ends should be stationary --- I like about 4 to 5 inches of the shafts together for use.
Depending on the application, it may be necessary to slide it in or out. Initially as I understand it was for the steering wheel to partially collapse to help cushioning the driver on an impact.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 04-19-2016 at 07:52 AM. Reason: words |
04-19-2016, 08:09 AM | #3 |
those pins shouldn't matter, as long as the shafts are tight inside one another....some movement won't be a problem. the problem with those shafts seems to be the "seal" sometimes it's hard to find, I read someone used a intermediate shaft from a jeep Cherokee or at least the seal off of one......
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
04-19-2016, 12:07 PM | #4 |
The pins are not sheared. I seem to have play in & out in the "head" where it mounts to the steering shaft. Was wondering if I am suppose to.
04-19-2016, 01:12 PM | #5 |
I'd say as long as you have axial movement-vs.side to side, you should be just fine.
Ben
04-19-2016, 02:01 PM | #6 |
Play where the shaft meets the mounting head to the steering gear may be a problem. Have someone take a look at it that has steering knowledge.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
