Old 11-10-2005, 10:01 PM   #1
purple gas
dash plug terminal removal
I want to install a 7 hole-guage dash. Question. How do I get the terminals out of the plug for re-location? What I mean is the wires go into a 12 terminal plug that fits in the back of the cluster. These wires have to be moved from there present postions to new places in the plug , or it's gonna melt down and won't work.. How then does one remove the individual wires, with the terminals still attached to switch them to their now positions. They don't seem to simply pull or push out, so there must be a clip that holds them in there spots. Where and with what does a person press to release these pieces?
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 11-11-2005, 01:51 PM   #2
purple gas
Re: dash plug terminal removal
TTT anyone?
Old 11-11-2005, 02:22 PM   #3
shifty
Questionable
shifty's Avatar
It might be the same way as listed in my HEI swap thread over at the FAQ forum for the firewall block?
Check it out:
http://67-72chevytrucks.com/vboard/s...6&postcount=20
To browse the entire thread, click here:
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-11-2005, 02:36 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Your question is not real clear could you give us a little more detail?
sneakysnake is offline   Reply With Quote
Old 11-11-2005, 03:56 PM   #5
purple gas
T T T again with new and improved question
Old 11-11-2005, 04:13 PM   #6
sneakysnake
This will tell you where to move them,but how,scroll to the middle.
http://www.gmcpauls.com/Tech%20Tips1.htm
Old 11-11-2005, 06:14 PM   #7
chops333
ive used a pick to release the brass terminals
chops333 is offline   Reply With Quote
Old 11-11-2005, 07:24 PM   #8
john
member #16
john's Avatar
There is a tab that sticks up on the terminal that snaps in. I use a small screwdriver or pick to depress it. Push in from front side to depress tha tab. If it does not release try the other side, they arent always in the same way. John
john is offline   Reply With Quote
