Old 01-24-2010, 03:11 PM   #1
phantom4
Anyone running a RamJet 350?
Curious if anyone on here is using this crate engine.
I am encountering some odd problems with it and am in search of others solutions.
phantom4 is offline   Reply With Quote
Old 01-24-2010, 03:17 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Anyone running a RamJet 350?
N2TRUX has one in his square body.
http://67-72chevytrucks.com/vboard/s...d.php?t=187680
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-24-2010, 07:43 PM   #3
phantom4
Thanks for the link, although I am trying to find others who drive these on a more regular basis.
I have some specific questions regarding some sensor values and am curious of what altitudes people are running these at.
Old 01-24-2010, 08:19 PM   #4
ipaintem
i've got one in the crate at the shop now, we are going to put it in a 64 with a tremec 5 speed. I will post pics on my site,www.jmcautoworx.com
ipaintem is offline   Reply With Quote
Old 01-24-2010, 08:53 PM   #5
wwotr
wwotr's Avatar
WAY OFF BASE HERE, BUUUUuuuuuuuuut,
There used to be a Cartoon when I was a Kid called "Roger Ramjet".
Being as my 1st name IS Roger, ewverone always used to call me that!
My Dad always called me "Leo Nomillini" (sp), miss him everyday.
(Back to your Regular Programing)
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 01-24-2010, 09:28 PM   #6
63chevyll
gets board easy.......
63chevyll's Avatar
the ramjet uses off the shelf GM sensors. What issues are you having?
63chevyll is offline   Reply With Quote
Old 01-25-2010, 12:07 AM   #7
phantom4
The major problems I am having are with the MAP and O2 sensors. The MAP will continually throw the DTC 34 Low Voltage warning. The 02 sensor will eventually stop outputting a voltage signal. Replacement sensors have been used in both applications. The replacement sensors were an attempt to bring the computer back within operating parameters. The engine ran better but was still showing signs of an inability to run a normal pulse width.
Per the shop, it looks like the engine thinks it is at sea level and the 02 sensor can only correct 20% towards leaning it back out. Overall the engine is rather lean at idle and overly rich at part throttle. Current plan is to change the gain values of the sensor and create a custom fuel and spark curve.
Just curious if anyone else has encountered any issues with this engine and application.
Old 01-25-2010, 02:34 AM   #8
63chevyll
63chevyll's Avatar
My 2 cents, make sure are getting the correct 5V ref , Signal and - to MAP....and those values are getting to computer terminal.
Old 04-29-2012, 04:51 PM   #9
x ReAcT x
I know this post is over 2 years old but heres my 2 cents. I know GM came out with an updated ECU, I believe it is the 4th generation ECU for this motor and perhaps they have worked out the kinks. Check with a GM Parts Dealer?
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 05-08-2012, 08:48 PM   #10
x ReAcT x
If i understand correctly the tremec 5 speed (T5) transmission was used on the s10? does it handle the horsepower and torque well? and also I see you have a 64 but i have an 86 gmc and im also going to drop the same exact motor in and my mechanic recommended the T5 tranny also; does it bolt right in or did you have to make any modification?
