Old 05-03-2012, 07:08 PM   #1
dliving69
dliving69's Avatar
Steering Column Help
Under the hood on the steering column what is the part called that the column rotates and lands onto when shifting. This is worn out in my truck and its causing me gears to slip into another gear, from reverse into drive and also wont hold second? Please and thank you.
dliving69 is offline   Reply With Quote
Old 05-05-2012, 11:29 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Steering Column Help
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-05-2012, 02:15 PM   #3
Daddy'O
Daddy'O's Avatar
I believe it is called the selector plate.
The truck my son and I are redoing had the same problem. The plate's tabs or tangs were extremely worn down. So badly if you slammed the driver's door closed the shifter would drop from park to reverse. Not good.
Rather than finding a replacement or having it rebuilt, we opted to upgrade to a rebuilt factory tilt column.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 05-08-2012, 02:24 AM   #4
dliving69
dliving69's Avatar
Thanks!
Old 05-08-2012, 02:24 AM   #5
dliving69
dliving69's Avatar
Originally Posted by gcburdic View Post
ttt
Whats ttt stand for?
Old 05-08-2012, 08:05 AM   #6
CigarMan
To the top
CigarMan is offline   Reply With Quote
Old 05-08-2012, 09:06 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
It brings your thread back to the top of the forum so others that may not of read/ seen it can read and hopefully provide some help.....we also use 'bump' as well....
Geoff with a G
Old 05-08-2012, 11:25 AM   #8
dliving69
dliving69's Avatar
Okay thanks
