Old 07-25-2004, 09:56 PM   #1
kickinasphalt
kickinasphalt's Avatar
What are you lifted/big tire guys getting for gas mileage???
I have had my 6" lift and 35's on for a few weeks now and starting to realize what crappy gas mileage I get. Now this pickup is no daily driver so it doesn't concern me that much. I haven't figured it out exactly but I think I'm getting around 7-8 MPG. I have a mild 350 with a 600cfm Edelbrock, manual trans and 3.73 (about 2500 RPM at 65MPH). Does the 35x12.5 have more to do with then the lift?
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 07-25-2004, 10:07 PM   #2
Mike C
Mike C's Avatar
I have 4" lift on the Jimmy with 35's and 4.10s. With a Jet Q-jet and little cam (210@.050) in the 331, it gets 14 mpg. It is also a manual trans.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-25-2004, 10:09 PM   #3
Mudder
Mudder's Avatar
I'm thinking (no way of really knowing) about 12 mpg with 35's and 4.10's.
Mudder is offline   Reply With Quote
Old 07-25-2004, 11:57 PM   #4
Pont
I need another Barley Pop
Pont's Avatar
About 10 mpg (with a BB & manual trans) with 35's and 4.10's
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-26-2004, 12:04 AM   #5
drink2mny
drink2mny's Avatar
HAHAHAHAHA
Good one!!
I say gas milage is over rated once you go big..
I figure with running in overdrive with 38's and 4.10's maybe 6-7..
Support The Board
drink2mny is offline   Reply With Quote
Old 07-26-2004, 07:30 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
With 4.10s and 35s around 10. The 71 w/ 4.56s and 35s not sure.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-26-2004, 07:33 AM   #7
Dean
Dean's Avatar
I refuse to check it....lol. All I can say is bad. Doesn't matter if I'm towing a trailer or not.
Dean is offline   Reply With Quote
Old 07-26-2004, 09:04 AM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I dunno either but, take really bad x your screwed = my mileage.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 07-26-2004, 11:18 PM   #9
stan79chevy
stan79chevy's Avatar
i get more smiles per gallon
i have 33's with 4.56 and that comes out to about 10 or less
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 07-27-2004, 06:20 PM   #10
badblazerbabe
Size does Matter
badblazerbabe's Avatar
Sucky, but I also drive mine everyday including to school three days a week!!!!
Who Said Bad Ass Toyz were just for Boyz?????
92 Chevy Blazer (6 in Super-lift w/ 35's)
71 Chevy Blazer 2-wheel drive
2006 GMC Sierra D-Max
72 chevy short bed 4X4
badblazerbabe is offline   Reply With Quote
Old 07-27-2004, 07:50 PM   #11
LONGHAIR
As crazy as it sounds, A lower gear ratio will probably help. If you go to a 4.10 or even 4.56 your in-town milage will likely go up. This is because you don't have to press the throttle pedal as far to get up to speed. The higher gears may be better on the highway.......it depends upon where you do your driving most.
LONGHAIR is offline   Reply With Quote
Old 07-27-2004, 10:46 PM   #12
smokkey1
Land Beast
stock 350tbi,th400 and 4.10 with 36's
I have know Idea, but I'm guessing around 10mpg
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
Old 07-27-2004, 11:14 PM   #13
1FaastC10
1FaastC10's Avatar
Originally Posted by drink2mny
HAHAHAHAHA
Good one!!
upgrade the gears to something lower (4.56+) and i bet your milage increases, as well as helps your trans survive. RPMs are just too low for it to operate reliably.
1FaastC10 is offline   Reply With Quote
Old 07-29-2004, 02:42 AM   #14
500HP/SB
please don't break
500HP/SB's Avatar
35's, 3.07(ouch!!!) dual quads(eeek!!), SM465, About 8mpg, 2000rpm at 65 mph
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 07-30-2004, 12:40 AM   #15
Bradleyworld
70 Chevy 4x4 with an almost new ZZ4 350, 4inch lift and 33s, I get a whopping 9MPG (on the friggin freeway!), and 8.6 MPG towing my boat.
That really sucks when you pay CA prices for gas and ya can't use regular!
Bradleyworld
Bradleyworld is offline   Reply With Quote
Old 07-30-2004, 11:12 AM   #16
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '69 has 35's & 4.10's with a mild built engine. Gets around 6-8.
The '72 has stock tires and 3.07's with a bone stock engine and it gets around 12-14. A/C greatly reduces that number!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-31-2004, 07:34 AM   #17
Gunny
runnin on empty
Gunny's Avatar
I have not lifted my 88 Suburban yet but with 31's and unknown gear ratio (have not had a chance to check yet) 6.2 diesel with the 700r4 I average 18 mpg at 75 mph towing my jeep or not towing my jeep - I am looking at lifting it around 5 - 6 inches and going with 33 wild country tires - at that time I will check the gearing and modify as needed.
now my 87 Cherokee 4.0 5 speed with 6.5 inch lift, 4.10's, 32 BFG's gets about 12 - 13 city and up to 22 highway (overall avg hwy is 20 mpg) at 80 mph - but I have bored the Thottle body, yanked out the breather box and fab'ed a cold 9 in x 5 in round air cone filter breather, hood vents (has lowered the temp 10 degrees at highway speeds), flowmaster 44 with 3 inch pipe plus a few other odds and ends to help performance.
my NON lifted T-Bird gets about 10 city and 14 hwy completely stock except for a 1406 edlebrock carb (300 hp 390 from the factory)
Gunny
88 GMC Suburban - 6.2 Diesel 4x4
87 Jeep Cherokee - 6" lift, 32 bfg's, way too many mods to list.
65 Thunderbird - Stock
United States Marine Corps
SEPIUS EXERTUS, SEMPER FIDELIS, FRATER INFINITAS
"Often Tested, Always Faithful, Brothers Forever"
Gunny is offline   Reply With Quote
Old 08-02-2004, 12:49 AM   #18
ABHaulR
ABHaulR's Avatar
around town 10
on the hwy with overdrive and 4:56 and 40's
16
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 08-02-2004, 10:06 AM   #19
Grim Reaper
Originally Posted by ABHaulR
around town 10
16
Dwayne
Cough Yeah right. Get the speedo check its off.
I get 9.2mpg hwy on 75 jimmy TRACKED WITH GPS. 350, TH350, Converted NP203, 4.10 and BFG 35's 4/6 lift
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-02-2004, 12:00 PM   #20
Destructo
I get about 12 in my 85 K10 with 4" lift and 33x12.5" tires, thats with a 350 with bolt-ons and a Q-Jet that doesn't run right part-throttle.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-02-2004, 12:01 PM   #21
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
All stock never rebuilt 350/205 w/ 32x11.5s and 3.07 gears gets me 11mpg hwy.
1972 Chevy K10 SWB
Bobalouie is offline   Reply With Quote
Old 08-24-2004, 08:22 PM   #22
Joey-D
City's Articulation Ramp
Joey-D's Avatar
My old 92 GMC had a 351 TBI with KN round top with a cyclone top, Hypertech chip, Throttle Body Spacer, and true dual exhaust, turbo 350 3.42 gears and 35s got 8 mpg no matter if I was on the highway in the city driving like a grandma or Jeff Gordan.
My new 85 with a mild 350 with a holly 650, sm465 direct drive, 4.10s and 38.5 Boggers get 8 on the highway and around 6-7 in the city, but then again I race stop light to stop light. I just love the yuppies in the drop tops coughing on my 3 inch dumps as the light turns green
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
