Old 10-19-2010, 01:27 PM   #1
john rod
door glass channel/division bar----?
time to replace parts in the doors of my '67 C-10 panel.
looks like i can buy a replacement filler for the division bar. however there is no chrome [stainless] bead. buying the ridged piece means lots of work, drilling out factory rivets and then remounting the vent and brackets. i did this on my '56 car. ugh. thoughts?
years ago i bought the glass run channel for a truck [curved corner, not square] [still have that pair in GM boxes-for sale?] can i buy square corner glass run?
i checked in a hollender interchange about the interior door opener [remote, as GM calls it] and there was no listing. i looked at several trucks and doors and they all look the same. so i am going to buy a '68-'71 remote and see if, in fact, it will fit a '67.
also Classic parts now has gray door handle escussions [sp?] so i will get 4 of them. maybe stop some wind noise.
thanks rod in AZ
john rod is offline   Reply With Quote
Old 10-19-2010, 02:36 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: door glass channel/division bar----?
can you post some pics of what you are trying to do?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-22-2010, 12:11 AM   #3
mosesburb
I had a V-8
mosesburb's Avatar
thanks rod in AZ
The filler in the division bar can be bought as just replacement felt/fuzzies. When I did mine, I left the whole thing assembled and put a fine wire wheel on a 4-1/2" grinder and ran it down the channel. That instantly removed the old fuzz. Then I put some Permatex weatherstrip adhesive in the channel, laid the new fuzzies in it and put the assembly back in the door. It works great.
As far as the square corner goes, I do not know of anybody making a Suburban only window run channel. When I did mine, I just cut the channel at a forty five and put it in. Looks good and functions as intended.
On the door latch part, I do not know if it is the same. Might want to post that question in the truck section as that gets more traffic.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
