12-18-2007, 02:53 PM | #1 |
chevy truck fan
pedal ideas & ???'s
all,
i am looking at trying to do something with our stock pedals (gas, brake, & e-brake) i am wondering what is available in the after market for the pedals that we have? most of what i see start for the '73 & up versions. are the 73-up pedals the same if not can these be "put on" the brackets?? any suggestions & or help would be greatly appreciated!!!! thanks!!!!!!!!!!! rodstored-72 |
12-18-2007, 04:26 PM | #2 |
Re: pedal ideas & ???'s
The 72 gas pedals are not hinged at the floor like the 67-71's. What are you looking to do? Something like the 70's chrome barefoot pedals, billet or the like?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
12-18-2007, 05:08 PM | #3 |
That's right, it's Copper!!
This is my setup, Ididit pedal pad for the brake and a complete pedal for the gas.
12-19-2007, 05:19 AM | #4 |
chevy truck fan
fastum,
that is exactly what i am looking to do. i may even copy if that won't bother you.... would you shed some light on where you got the pedals & how you installed them???? thanks!! and keep the ideas coming. rodstored-72 |
12-19-2007, 05:26 AM | #5 |
Questionable
Yeah, I posted a similar question about 2- and 3-pedal kits a couple of months ago. Didn't get much helpful info. Wishing you the best of luck.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-19-2007, 08:18 AM | #6 |
I'm sorry!! Those pedals are from Lokar. Mine are older models, check the site and I'm sure you can find something that will work.
The brake pedal pad is for a 55-57 chevy I think. I had to do some cutting to get it to fit correctly. http://www.lokar.com/product-descrip...assemblies.htm |
12-19-2007, 09:26 AM | #7 |
chevy truck fan
fastom,
thanks!! i am checking into those. i think that i might go with the assy for the gas pedal. shifty, thanks!! i will try to help you out as well. i think most of the guys on here are more into the deluxe orig, pedals. i like those as well, but the look i am going for is a little more "streeetrod".. thanks!!! rodstored-72 |
