Wiring Question
I'm going through all of my wiring in the truck, replacing what needs to be replaced, but am not experienced in wiring. I've found a wire that was about shot, but not sure what it is.
It connects from the starter up through the middle of the firewall, in with some other wires. It connects with a very small circle end connection at the starter. Would anybody mind helping me out with what this one is? I appreciate it. '70GMCStep '65 Chevy LWB '70 GMC Stepside Last edited by '70GMCStep; 01-24-2010 at 11:56 PM. |
Re: Wiring Question
is it purple? does it bolt on to the really small post?
Re: Wiring Question
I'm a bit color blind, but it does connect to the small post down there.
Re: Wiring Question
there should be two wires. one is the battery cable . the other witch should be purple should be your starter wire that comes from your ignition switch . can u post a pic
Re: Wiring Question
Thanks for the reply. Not able to post yet. I wonder if there are wires for thisapplication on the market (been doing harnesses this week) for this or if this is just a replace with common wire of a certain gauge? Thanks.
'70GMCStep |
Re: Wiring Question
any wire of the same gauge is just the same
Re: Wiring Question
Thanks for the reply. Not able to post yet. I wonder if there are wires for this application on the market (been doing harnesses this week) for this or if this is just a replace with common wire of a certain gauge? Thanks.
'70GMCStep |
Re: Wiring Question
There is a lot of wiring info in the FAC section at the top of the forum
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Re: Wiring Question
Hey thanks chopper, and 62. Disregard last post, I didn't see your reply before I sent mind. I will get on this replacement. Learning as I go. I appreciate it!
'70GMCStep Last edited by '70GMCStep; 01-25-2010 at 12:28 AM. |
Re: Wiring Question
are you using an hei distributor?
Re: Wiring Question
I am running an H.E.I. on my 350.
Re: Wiring Question
on the starter you should have two small posts. one has the letter s witch is for start where the purple wire goes. the other one has an r for resistor so you dont need that one, its for a points distributor
#13 |
Re: Wiring Question
Hey thanks for the info. chopper, I appreciate it. I'll make another go at this wire. Electrics are a bit confusing to me but gonna keep working on it.
'70GMCStep '65 Chevy c-10 LWB ![]() '70 GMC Stepside ![]() |
