01-14-2022, 01:26 PM | #1 |
Dimple Dies
Been trying to find a couple of smaller sizes and am coming up short.
Sizes: 1/4''--5/16'' and 3/8'' anybody? Can find larger sizes up to 3'' and smaller down to 3/32'' for aircraft. For some reason those 3 sizes come up blank |
01-14-2022, 01:30 PM | #2 |
Re: Dimple Dies
Have you tried the metric equivalents?
01-14-2022, 02:33 PM | #3 |
Re: Dimple Dies
Nope, not a bad idea----nothing found but the same searches that came up prior
01-14-2022, 04:07 PM | #4 |
Re: Dimple Dies
Try Trick-tools.com they seem to have a wide variety.
01-14-2022, 06:12 PM | #5 |
Re: Dimple Dies
Trick Tools or Hammerfab
https://www.hammerfab.com/shop/p/crater-maker-set https://www.trick-tools.com/
01-14-2022, 06:42 PM | #6 |
Re: Dimple Dies
Nope, both Hammer fab and trick tools start at 1/2'' and go up from there. Thanks for the links.
What I'm trying to make is a non-slip tread plate out of 18 ga for some custom running boards I'm making for my 91 Suburban, hence the smaller dimples |
01-14-2022, 07:14 PM | #7 |
Re: Dimple Dies
Well.... My bad. I could of sworn Levi had some to 1/4" in size.
01-14-2022, 09:19 PM | #8 |
Re: Dimple Dies
Not according to his website anyways
01-14-2022, 10:13 PM | #9 |
Re: Dimple Dies
I just read an article that a guy used some sockets for dimple dies because he didn't have any. I thought it was on here. But I can't remember.
01-16-2022, 11:32 AM | #10 |
Re: Dimple Dies
If you have a drawing of exactly what you want I may be able to make a set for you? PM me if interested.
01-16-2022, 01:17 PM | #11 |
Re: Dimple Dies
Whether it happens or not..... Awesome offer!
01-16-2022, 03:46 PM | #12 |
Re: Dimple Dies
01-16-2022, 04:34 PM | #13 |
Re: Dimple Dies
Actually I'm not exactly sure what I want. I do want to create a non-slip tread on 18g steel for some frame mounted running boards/rock sliders for my suburban. I thought a smaller dimple would work if I can get a set of dies that I could utilize in an arbor press or on my small bench top hydraulic. Saw some where in my searches that maybe a 3/16 may work.
01-16-2022, 09:07 PM | #14 |
Re: Dimple Dies
Brown Avaition Tool, Oklahoma City has dimple dies the size you are searching for. They are online
01-17-2022, 12:21 AM | #15 |
Re: Dimple Dies
The 5 Piece Raised Recess Dimple Die Set by hammerfab is
$360.00 The other set is $55. Used a rivet tool. I did a Google search and didn't find them. Good sleuthing guys. cheers. |
01-17-2022, 05:55 PM | #16 |
Re: Dimple Dies
These would be good for step or tread plate, but it's $195.
https://www.hammerfab.com/shop/p/flush-recess-die-set |
01-17-2022, 11:16 PM | #17 |
Re: Dimple Dies
Not sure what your design is but you can buy dimple tread material.
https://www.directmetals.com/product...afety-grating/
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
01-18-2022, 10:22 AM | #18 | |
Re: Dimple Dies
