09-07-2021, 09:35 PM | #1 |
Lokar ACA-1811 Automatic Column Shifter Linkage
I bought this recently and installed it on my truck briefly when I was planning on getting an exhaust system that was tucked up between the frame rails. I ended up getting more of a traditional exhaust system, so I went back to the stock linkage. The rod started out at 26" long, and I cut 6" off of it to work with a 700R4 and engine mounted in the forward position. I paid $88.95 plus shipping and tax.
$75 shipped |
09-08-2021, 06:57 AM | #2 |
Re: Lokar ACA-1811 Automatic Column Shifter Linkage
Do you have a Big Block? If so, that should work for me.
09-08-2021, 11:23 AM | #3 |
Sorry, I should have mentioned that I have a small block. Is the transmission position different for bb vs. sb?
09-08-2021, 11:53 AM | #4 |
I'm not 100% certain on that myself, as I am just getting around to start putting things together. I do know that the big blocks are mounted in the front position for sure, but as far as where the transmission falls inline I don't. All I know is that I have a big block and going to run a 700R4 behind it. All things considered. Would you consider $60 shipped?
09-08-2021, 11:55 AM | #5 |
Let me see how much shipping is going to be
09-08-2021, 12:19 PM | #6 |
No problem. Thank you.
09-08-2021, 12:28 PM | #7 |
Based on shipping cost and trying to get back half of what I spent on the linkage, I could do $65.
09-08-2021, 01:05 PM | #8 |
That sounds fair. Before I send any funds though, I'm also thinking about the calipers you have for sale in the other thread. I may already have what I need, but I need to double check first. I will reply to that thread, so that everything is on the up and up. Thank you.
09-08-2021, 01:06 PM | #9 |
Sounds good
09-09-2021, 02:31 PM | #10 |
Shipped
