09-14-2022, 01:07 PM | #1 |
Moderator
Fuel Pump Took a Powder
My mechanical fuel pump took a dump this morning. It's a Top Street Performance Mechanical Fuel Pump JM1003BK. It only has 1,033 miles on it since I installed it. The pump arm wobbles all over the place unlike when it was new. I changed the old carter out for this in January along with the inlet and outlet positions of the fuel lines.
Doesn't seem like they build stuff like they used to . Of course for the price I should have known better. Trying to save money and have to buy twice. I guess I could get the same unit and hope it lasts till winter and change out for an electric. Which will probably take a dump on me in 2,000 miles.
09-14-2022, 07:40 PM | #2 |
Re: Fuel Pump Took a Powder
Dang, that's a bummer.
I got a Delphi mechanical pump when mine went out. Crossing my fingers that it will last longer than that
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-15-2022, 03:43 PM | #3 |
I have been using a Holly mechanical fuel pump for many years and it has worked vary well.
09-15-2022, 05:28 PM | #4 |
Moderator
That's good to hear.. They have a #12-834 pump that will work but I have to make small changes to the inlet and outlet tubing. I may consider it instead.
Well the new one is all back in and working, Summit had it at my door in less than 24 hours and I didn't even pay extra for shipping. Like I said this winter a change must happen either way.
