Old 06-12-2011, 05:52 PM   #1
dstarrett
dstarrett's Avatar
installing large rear window
Noticed that the top edge of the window is not perfectly straight , but, tapers down from about 8 inches out from the corners. Why? Also could you attach the rubber with urethane so it would not come off during the install? Other helpful hints?
dstarrett is offline   Reply With Quote
Old 06-12-2011, 07:25 PM   #2
64fleetside
Re: installing large rear window
Put rubber in cab hole, work glass in, then install center spline of rubber.
64fleetside is offline   Reply With Quote
Old 06-13-2011, 06:12 AM   #3
mbgmike
yes. the windows install pretty easy. I guess you could use some urethane to hold the rubber on before the glass goes in but i personally have never had to . the rubber usually holds itself on.
mbgmike is offline   Reply With Quote
Old 06-13-2011, 04:06 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
Me and a buddy spent a few hours trying to get the rear window (small) installed in my '64 this past weekend. I have done rear windows before in later trucks, but man, this thing was a pain. At first, we tried to install it with the seal untrimmed (not butted together), no dice. Then we tried to install it with the lock strip removed, but the seal wanted to roll on the edges. Then, we installed it with the lock strip inserted and fought it for an hour, but finally got it.
Dumb question: What is the best method for doing this? I have a feeling I did it the HARD way.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-13-2011, 04:14 PM   #5
jocko
jocko's Avatar
I always thought the lock strip was supposed to be installed after the window was inserted, i.e. as a last step. But then again, I've never installed one! I can only imagine it is a bit of a pain.
The two ways I've heard were:
a. install rubber on glass, then wiggle the assembly into the opening. THEN install the lock strip.
b. install the rubber into the hole (maybe with a little silicone just for the purpose of holding the rubber in place) and then insert the window (agreed, it might be hard to not roll the edges, but maybe some soapy water on the rubber might help reduce this tendency) and THEN install the lock strip.
Not sure if a) or b) is better (I'd vote for B first if I were doing it) but the common thread is to always install the lock strip last.
my 2 cents - and just to be clear - I have NOT done this little job - just passing along.
Old 06-13-2011, 04:55 PM   #6
A.T. RockDriller
A.T. RockDriller's Avatar
Maybe this is common knowledge.....in which case ....you already know.
But just in case... here's the easiest way Ive ever done it.
30 years of evolution on technique has me doin' the following:
* It's a bit messy sometimes, so cover or mask the dash top or seat tops just in case. Any access sealer wipes off paint with prep-sol.
* If you plan to use sealer....which I usually do....start by wiping down your new rubber with some kind of prep-sol.....even inside of the grooves.
* Apply sealer to the groove for the glass.
* Put the rubber on the glass
* Put Sealer inside of the outer groove....all the way around.
* Take a piece of soft, pliable nylon cord (3/16" or so by 10 feet) and lay it in the groove (right in the sealer) along the top and down each side leaving the ends free, trailing from the lower corners.
* From the outside, throw the loose cords inside the opening and set the bottom groove in place on the flange. Work the bottom corners of the rubber seal into place with a narrow, plastic putty knife.
* Have your assistant hold against the outside of the window while you get your butt inside and take one side of the cord and pull in and up towards the upper corner a foot or so. Just pull it towards you and it will kinda squirt into place like a zip-lock bag. Then do the other side about the same..
* Have your assistant push on the glass directly across from where you're working.....not too hard. The sealant works like a lubricant and if you go a few inches at a time (sometimes using the putty knife), working around the corners, alternating side to side towards the center of the top, just pulling that cord out as you go.......she'll just ease right into place. When you finish, go out and push it into place the rest of the way to seat it.............Just slick as a whistle.
* One more hint.....Take a couple plastic grocery bags to put the cord into as you go.....It get's messy. Wear Nytrile gloves. Clean up around the new seal with prep-sol or whatever.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 06-13-2011, 06:33 PM   #7
mbgmike
Man I never had those problems. Could be the gasket you used. I only use good gaskets. I just put the rubber on the frame insert the glass and intall the locking strip. I never used a rope on the rear windows with a locking strip.
Only time I ever use a rope is on a one piece gasket. sometimes I shoot some silicon into the groove before installing the glass.
Old 06-13-2011, 07:34 PM   #8
A.T. RockDriller
Gee Whiz, guys.........Maybe I need to go back to school.
Are the mid-'60's Chev's special...?
All I know is that regular 1 piece rubber windshields and flat glass with rubber gasket fits are hell to install dry and the above technique is the only way to go.
The idea of just puttin' the gasket in the hole and pushing the windshield into the groove afterward makes me wonder what holds it in and keeps the water out..?
I have seen and installed expansion strip type moldings and as you explained....they need no special tricks.
I never have done the windshield in my '63, so maybe I'm in for a surprise.
BTW, Mike, I noticed you're from Texas.
I'm from the Portland area......70 to 80 inches of rain a year. Around here, if you slip up one time....one flaw in your frame prep or a nick in the gasket....and by golly, It's gonna leak.....all freakin' year.
We usually use the special sauce just to be sure.
But then again.....I'm the kinda' fella that throws away the pan gasket and grabs a caulking gun full of GMS.
Leaks kinda' pi$$ me off.
Les Hunter
Old 06-14-2011, 09:56 AM   #9
64fleetside
If your rubber uses the locking strip(like factory on rear glass 60-66), it's the last step-a tool(KD sells one) is made to run the strip into the rubber once the window is set in place, or you can push it into the groove suing a bone or small. If its tight like most big windows a little dish soap will help. It's usually easy-the last small window I installed took me about 5 mins start to finish by myself.
Old 06-14-2011, 11:49 AM   #10
chevyrestoguy
That's good info.
Like I said before, I've done windows in my later model trucks and never had a problem. The lock strip kinda threw me, and after the attempt (no lock strip) where the seal kept rolling on the corners, I installed the strip and the corners laid down perfectly. Getting the seal to pull on the inside was a whole different matter. I used too small of a string and didn't use any lube until I was almost done. I used a cheap (Counterparts brand) seal that was a trim-to-fit type.
I'll do better next time, but there's no way I'm going to attempt to install the front windshield.
My build threads:
Old 06-14-2011, 12:38 PM   #11
64fleetside
the front one ain't too bad if no trim, the trim really cranks it up a few notches IMO.
Old 06-14-2011, 08:21 PM   #12
mbgmike
Originally Posted by chevyrestoguy View Post
That's good info.
thats your problem. We don't sell counterparts gaskets any longer, They are not quality at all. we sell Precision for these trucks
Old 06-14-2011, 08:24 PM   #13
mbgmike
not sure what 70 inches of rain looks like. Has not rained here like 4 or 5 months. I don't install them dry.I use a lube
Old 06-14-2011, 09:45 PM   #14
chevyrestoguy
I'll be getting my next seal from you, Mike. I wasn't impressed with Counterpart. This is for my beater truck, so I went with the cheapest gasket. I'll bet that a Precision gasket is not too much more than a junk gasket.
My build threads:
Old 06-26-2011, 05:08 PM   #15
Scot_Douglas
Scot_Douglas's Avatar
Well, slap my a55 and call me stupid.
I just spent about 3 hours with a counterpart seal and my oem rear windshield. I now have broken glass scattered all over the driveway - and I'm about ready to drive down to Missouri and shove these seals somewhere inconvenient for someone at classic parts.
I can count on one hand the amount of times I've been this angry.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 06-26-2011, 05:15 PM   #16
Scot_Douglas
Would you mind sharing where in the he77 you hide them on your webpage?
1966 C10
Build 'Fread
Old 06-27-2011, 06:29 PM   #17
awbrown
I always used the string/rope method.. put a lot of sliders in trucks that way ....
awbrown is offline   Reply With Quote
Old 07-01-2011, 12:17 PM   #18
63MOUSE
on my 63, i have had 3 windshields put in, they are a huge pain because of the wrap around glass. but i have always used A.T. rockdriller s method also, the back window, rubber and locking bead all together with something slippery in the groove, wrap a small cord inside the groove get one part started and slowly pull the rope with some one putting pressure against it and the back window is not to bad
63MOUSE is offline   Reply With Quote
