06-25-2005, 03:22 AM | #1 |
Flip Kit or Lowered Leafs & Shackles
I am planning on lowering my 71 LWB. The rear suspension is leaf springs and I was wondering how many inches a flip kit would lower the bed? The total I can get with new lowered leafs and shackles is 4" + 1.5" = 5.5". Let me know your opinion on both methods of lowering.
Plans for the front drop is 2.5" spindles and 1" springs. What are the other options and your opinion? I am thinking of rebuilding the frontend at the same time. Should I buy a kit or pieces from Autozone or Kragens or ? Thank in advance.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-25-2005, 01:01 PM | #2 |
faster, faster, faster
if yu flip it you will have to notch it with that much drop or you will bottom out on the frame rails alot. And forget about hauling anything. I would do the drop leafs and shackles, you will still need to notch, but just not as much, and it will ride better. I lowered the 72 my dad drives with 4" leasfs and it rides sweet, no notch, but with the 5.5, I would notch. With the 3.5 up front, and the 5.5 out back it will sit perfectly level too, provivding the tires are the same diameter all around.
I'm going to Law School, wanna debate? It's good practice. |
06-25-2005, 01:08 PM | #3 |
A flip kit will get the same drop w/o having to knock out all the rivets & doesn't change your current spring rate. I believe flip kits are even cheaper than the 'shackles & hanger' combo but I'm not 100% sure on that.
I say flip it & get a bolt in c-section.
06-25-2005, 01:25 PM | #4 |
I am not sure, but I don't think shackles require that you to relocate the mounts. The drop leafs also have the stock spring rate, just not as much arch. And I am nervous about the bolt in anything right there. The leafs are around 350 or so, and the shackles I am not sure about.
06-25-2005, 02:01 PM | #5 | |
The 'shackles & hangers' route is more work because you have to unbolt the springs & remove all the rivets for the front hanger. The rear shackle simply requires unbolting the spring & swapping the shackle after unbolting it from the hanger. The bolt in c-notches have been used on many different applications for many years w/o issue. If the 'bolt-in' feature is a concern, a person could always bolt it in & then have it welded @ a shop or something (this is what I did when I knew I would be pulling my car trailer more frequently). If your even remotely close to the price on the dropped leafs, the flip kit is much cheaper. I looked up pricing in an old CCP catalog I have: 63-72 Rear leafs (dropped or stock height).. = $369 + 63-72 Drop shackles @ $69 = $438. The flip kit is $150 @ Sport Truck Direct & $140 @ DJM. The c-notch is a wash because either method of drop, if over a certain amount, will require one.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-25-2005 at 02:12 PM. |
06-26-2005, 12:21 AM | #6 | |
Thanks for the double Texas support. The members of this board are a dream come true. Father, big brother, mechnaic, engineer, dreamer and practician all in one.
I was not aware that I had to relocate anything if I used the drop leafs and extended shackles. I would have been totally unhappy finding out I had to relocate the brackets. As the truck sits now the tires are 275x60x15 and are 27" high. The front fender-well is 5.5" off the tire. The rear fender-well is 6.5" off the tire. How high should the stock front and rear fender-wells be off the tire? I would like to lower the truck to the top of the tires or within 3/4". Do any of you know the number of inches that the flip kit will lower the rear? I was excited about getting a new spring to improve the ride. Guess I will remove the leaf springs, take them apart, clean and smooth the individual leafs, and reinstall them using sheets of a word I can't think of at this moment. I plan on relocating the rear shocks and replacing the ball-joints and bushings with another pair of A-arms. This will allow me to complete the project quicker and get the truck rolling again. Then I want to relocate the gas tank and get some of the body work started that needs welding. The bed has gas tank doors on both sides though no gas tanks. Would a truck with two side tanks have heavier suspension that would make it sit higher than the average bear? I also plan on towing a 14 foot camping trailer. That is if I can convince my neighbor to sell it to me. Older Nomad with toilet / shower and awning. Where is the beer Thanks again. Quote:
06-26-2005, 01:08 AM | #7 |
The amount of drop from a flip kit is dependant on the numbers of leafs in the spring pack.
Typical 1/2 tons have 5-leaf spring packs that would yield about 5" of drop & the HD option was 8-leaf spring packs which are closer to 6" of drop. If your plan is to swap out the a-arms w/another set that's already been rebuilt, upgrade to the 73 & later arms to get the better riding rubber bushings vs. your current steel/rubber-lined bushings. I have both year models that are dropped w/the same methods & you can definitely tell the difference. Good luck regardless of which method you choose.
06-27-2005, 02:00 AM | #8 | |
Thanks Scoti for the drop information and the tip about the 73 & later A-arms. Did you use stock bushings or aftermarket? Any suggestions? Tim
06-27-2005, 01:05 PM | #9 | |
