Junior Member
![]() Join Date: Jan 2006
1972 Blazer transmission swap?
I am wanting to change (swap) out a 4 speed manual transmission with a automatic 350 turbo trans. Will the transfer case from the manual trans mate to the 350 turbo trans and vice versa? Also are the transmission braces the same on an auto and standard? Mike
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: 1972 Blazer transmission swap?
No problems with the transfer case,it's the adapter that goes in between the trans and T/C that's different.
the th350 adaptor is on the left,the sm465 adaptor is on the right. ![]() ![]() here is an article on swapping a manual (SM465) to automatic (TH350) conversion. http://www.geocities.com/spencerhut/...trans_swap.htm
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 01-20-2006 at 01:43 AM. |
Junior Member
Thank you for the info. Mike
so if you change out a manual on an old 65 2 wheel drive with an auto TH350 will you be forced to get a new driveline because of the different lengths trannys?
something I was wanting to do eventualy. Mike... Last edited by Gyva; 01-20-2006 at 04:09 AM. |
The transfer case that was attached to the SM465 has a 10 spline input, you will need to find a case with a 27 spline input to use behind the TH350 or change the input in the t-case you have.
Tim |
#6 | |
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
Try to find a complete unit:TH350/adaptor/205.It`ll bolt right in and you can sell your complete 4spd unit for a trail-rig.
It's pretty funny.
I have a TH350 in mine and would love an sm465.
1971 GMC Jimmy 350/350/205/D60/14bolt on 38's 1984 M1008 CUCV 6.2/TH400/208/D60/14bolt on 36's 1991 W250 5.9/G360/205/D60/D70 on 33's (tow-rig) Lotsa Full Size Jeeps (J10/J20)! Adam |
#9 | |
Junior Member
Where you at? If you are close to Fort Worth, Texas I would trade. Mike |
That`s what I was wonderin`.PM that guy to make sure he knows your interest.
#11 | |
'71 Chevy Blazer
i just did the opposite swap... interesting side note, i didn't have to have my drivelines altered at all... i thought for sure that i would have had to
'71 K5 Blazer (new project / daily driver) "If you are not working to improve the situation, you have no business complaining" |
#13 |
Junior Member
Will a 700R4 bolt up to the 1972 transfer case?
#14 |
With a output shaft modification,yes.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#15 | |
Check out GMTrucks.org
