Old 02-14-2007, 02:45 PM   #1
cameeks
Long Fleet Club
cameeks's Avatar
Anyone switch from a powerglide to a 700r4?
For the people who have done this did you get to you the same shifter linkages or did you have to modify? Also would like to see some finnished pics as well. I'm starting mine in a few weeks.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 02-14-2007, 10:38 PM   #2
mnunn454
mnunn454's Avatar
Re: Anyone switch from a powerglide to a 700r4?
Dunno about the shifter linkages, but I'm happy for you about upgrading to a 700R4 from a PG. You should see a WORLD of difference both on the bottom end and on the top end.
Suggestions though:
Make sure you run a transmission fluid cooler. The 700R4 is less tolerant of overheating.
Pay particular attention to the Throttle Valve (TV) adjustment. It's critical to get it right. No, It's critical to get it right. May I say It's critical to get it right? Not doing so will result in unpleasant shifts and shortened tranny life.
Finally, getting the torque converter to lock up is a simple thing, but may require a few parts. It's worth the hassle in the long run to hook it up as it improves mileage even more than the overdrive, and will reduce tranny heat buildup.
Happy motoring. You're going to be impressed to say the least.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 02-16-2007, 02:11 PM   #3
cameeks
Long Fleet Club
cameeks's Avatar
Update. I'm starting it next week. I have everything else down but the shifter linkage. Want to know if I have to modify it so I can do it while the engine is out.
Chris Meeks
Old 02-17-2007, 12:33 AM   #4
pocoloco71
pocoloco71's Avatar
It's been a while, but i did use my orginal shifter with orininal no tilt
colum. I'm sure we tweaked it but not much. Its been in since 95. Classic
perfomance products offers a nice one for 20 bucks. Either way u still
have to tweak them to "time your tranny shifts". Mainly because of th
4 speeds and the tranny being about 4 inches farther back. I think we
made sure new tranny was in park and the colum was in park befor we
took any thin loose. Hope this helps
pocoloco71 is offline   Reply With Quote
Old 02-17-2007, 10:32 AM   #5
cameeks
Long Fleet Club
cameeks's Avatar
Can you look at yours and tell me if turning it counter-clockwise untile it stops if that is park? It was out when I bought it. Also is it P-R-N-D-3-2-1?
Chris Meeks
Old 03-11-2007, 09:21 PM   #6
pocoloco71
pocoloco71's Avatar
Wink Re: Anyone switch from a powerglide to a 700r4?
sorry been sick with a kidney stone. I bought a column shifter linkage
from ccp. It was pointed at 9:00 in park and 6:00 in low. yes that is
the gear rotation. poco
Old 03-12-2007, 08:25 PM   #7
cameeks
Long Fleet Club
cameeks's Avatar
I got it put in the weekend befor last. I got the linkage from an 80's suburban and the pointer is in the indicator area still. I jst have to get the new display for the column.
Chris Meeks
Old 03-14-2007, 11:27 PM   #8
pocoloco71
pocoloco71's Avatar
I ran mine for a long time with the old none tilt column, It was only about
a year ago that I put in the ididit column and got the shift linkage from ccp.
I got some qualified help with the tv adjustments and the wiring for
torque converter lock up off the brake switch. Anyways I bought mine
from street and performance(mena, arkansas) in 1995 it's still going.
I hope you have the same good fortune. poco
Old 03-15-2007, 09:07 AM   #9
cameeks
Long Fleet Club
cameeks's Avatar
TCI has a new item out that changes the valve body for $250
http://tciauto.com/WhatsNew/Files/TC...eValveBody.pdf
Chris Meeks
