Old 03-13-2007, 07:26 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Tranny Mounts & Driveline Vibration
Got a bad vibration in my 72, narrowed it down to drivline vibes. My tranny mount (700r4) seems to making the tranny sit about a 1/2inch to the driver side. Could this be enough to cause a vibe? It is a rubber mount, can i change it to polyurethane without changing the motor mounts to poly too? Getting the shaft balanced tomorrow to really narrow it down, right now it doesn't have any wieghts on it.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 03-13-2007, 08:02 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Tranny Mounts & Driveline Vibration
Might wanna get a new carrier bearing, just to be on the safe side
They're not that expensive & well worth no having to pull your drive-shaft again
Or do the SWB's have carrier bearings ?
I'm new to the 67-72 stuff
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-13-2007, 08:39 PM   #3
Blue85
Oilfield Trash
Blue85's Avatar
no carrier bearing, just a single shaft
87 Chev 3+3 4x4
Old 03-13-2007, 08:39 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Hmm
Sinister
Killer
Old 03-13-2007, 09:05 PM   #5
cdowns
cdowns's Avatar
polyurathane mounts will increase the vibration// have you checked the pinion angle since dropping the truck? have you also checked the drireshaft yoke to make sure theres enough free play when installed in the tailshaft of the tranny?
Old 03-13-2007, 09:13 PM   #6
wibilly
wibilly's Avatar
corvette engine and trannies sit at more of an angle than that to make room for the stearing colume so idoubt that alone is your problem. if you go with poly mounts i think you should replace all three
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-15-2007, 12:54 AM   #7
Blue85
Oilfield Trash
Blue85's Avatar
think i sourced the problem, got the shaft balanced today, and it was waaaaay out of wack, the guy was suprised that it didn't vibrate worse, seemed to think that someone had made the shaft at home. But now it snowed again so i wont be able put it back in the truck and test drive for a while.
87 Chev 3+3 4x4
