Air ride with front drums?
Okay, I'm new here so I hope this is the right place to ask and that it hasn't been asked a thousand times before.
I'm considering going with a Stage 1 air ride kit on my 69 C10. The deal is, I want to keep the 6 lug drum brake set up. Does anybody know if there would be any clearance issues or anything with running bags with the stock spindles and drums up front?
_______________________________________________________________ '69 C10 lwb stepside |
Re: Air ride with front drums?
Nothing? I guess I'll have to give Porterbuilt a call.
You shouldn't have any clearance problems with the drum brakes, but if you're keeping the stock control arms you won't lower it any if that's what you're trying to do. It might actually ride higher. You'll have to cut the stock bump stop brackets out to make room for the bags on the lower control arm. Then fabricate your own bump stops.
Here's a thread I made back when I was learning how air ride works... http://67-72chevytrucks.com/vboard/s...d.php?t=651651 |
![]() Join Date: Jul 2018
To each his own, but I have to ask: why??? Your about to drop some coin and labor, why not do brakes too? Huge upgrade in stopping power.
Posted via Mobile Device |
#5 | |
#6 | |
