engine/trans problem???
i have this 1963 chevy c10 manual trans, its been sitting for almost a year after i worked on it and restored it, engine runs great, has new carburetor, new fuel filter, new sending unit new fuel tank, new alternator, i mean it is ready to drive,,,,,
but after i finished restoring on a tight budget i was wanting it to drive it but every i mean every time i try to drive it and shift into a gear and press on the gas it dies! so i left it for almost a year sitting in the shed its all dusty now, but i have been working on a 1982 c10, |
Re: engine/trans problem???
Let me ask you this, does it just die when you touch the gas, or when you begin to disengage the clutch WHILE you apply the gas. I wonder if it's a motor problem or a drivetrain problem. Does the motor run perfectly smooth in neutral and/or in gear with the clutch fully engaged? Can you easily put the tranny in gear with the motor running and not stall?
in neutral in runs smooth u can ever press on the gas and it accelerates very well,, but when i press the clutch and turn into gear then slowly begin to release the clutch and pressing the gas it dies
does it try to move at all?
it does move like 3 to 4 feet then dies
dumb question here do you know how to drive a stick? just starting with the basics
just basics... but i know theres something wrong with this truck because i have drove other trucks easily
maybe because its old its a different way to drive them?? |
So when you hit the gas it dies? Do you let off the clutch an ease into the gas also? Are all your vacuum lines hooked up like dizzy advance? Timed correctly?
i mean it doest die right away it stalls then dies,
yea im easy on the clutch and gas, also thats one thing i have not checked is the vacuum lines, |
Is it an original type tranny with the super low 1st gear? And as mentioned before, vacum lines for sure need to be checked and so do the gaskets between the carb and intake, and the intake to the heads. You know the trick right? Spray a suspected intake leak with WD40 and if the motor speeds up you need to investigate the gasket.
i will check the vacuum lines this weekend and i guess its the original transmission,
sounds like your in third gear
#13 |
what do you mean
#14 |
![]() Join Date: Feb 2010
He means are you starting in 1st gear or 3rd? If third it will always be diffucult to get going. Is this a floor shifted 4 spd or coulmn shifted 3 spd? if its a 3 spd on the coulmn are you going for 1st gear? Do you know how to identify the trans you have?
#15 |
3 speed Muncie is a "H" pattern rev - top left, 1st - low left, 2nd - top right, 3rd - low right
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#16 |
Here's another question? And it's happened to me, is the parking brake on?
#17 |
floor shifted trans and no brake is not on
#18 |
did you add the floor shifter?......just for ****s and giggles...try starting off in second gear
