Old 04-22-2024, 06:46 PM   #1
dhigdon@southerntank
u joint
On my 67 c10 i'm pretty sure the 12 bolt differential is original to the truck. The u-joints should be 1310s, I think. after installing them I realized I have about a 16 of an inch slop side to side in the pinion yoke, between the two tabs. Measuring between the two tabs I get 3.279. The 1310 measures 3.219 so that gives me the 16 of an inch. I have looked at Spicers u joint catalog and can not locate a u joint that measures 3.279. Is there a u joint that measures 3.219 and 3.279 the other? I know they make conversion u joints but those convert from one cap diameter to another. Is the 16 of an inch going to be an issue? I would think so but don't know for sure. Anyone run across this can shed some light on it for me.
dhigdon@southerntank is offline   Reply With Quote
Old 04-22-2024, 07:06 PM   #2
Re: u joint
the tabs look different, almost like some has been removed from the left one
Old 04-22-2024, 07:26 PM   #3
Accelo
Accelo's Avatar
Re: u joint
I also think you may be looking in the wrong place. Check the flange, maybe another member has one they can measure for you?
Accelo is offline   Reply With Quote
Old 04-22-2024, 08:35 PM   #4
HO455
HO455's Avatar
Re: u joint
I believe the yoke is damaged or someone has modified it. I found I had a bad yoke on my Burban some time back. I believe it is caused by tightening the U-joint down when one or both bearing caps are no properly located in the yoke.
Photos are from my bad one.
The distance from the inside edge of each tab to the center of the pinion shaft should be exactly the same. See my crude drawing.
RIP Bob Parks.
Old 04-22-2024, 09:37 PM   #5
jerry moss
Born Psycho
jerry moss's Avatar
Re: u joint
i agree, the yoke on your pinion is bad, the tab on the right side in the picture is definitely shorter/smaller than the one on the left.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 04-23-2024, 03:13 PM   #6
RichardJ
Re: u joint
Someone may have dropped a needle into the cap, making it too wide.
Could the cap shear the metal off when tightened without the bolts or something else breaking?
Could some guy chiseled the tab to make it fit?
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-23-2024, 03:54 PM   #7
kwmech
Re: u joint
Straps are supposed to be a one time use. When to bolt gets tightened down they will actually stretch some to lock the u-joint cap down. when that doesn't happen the cap will spin and act like a small lathe and remove the end tab/s. If you look at the old cap it should have a polished circle where it was spinning.
