Old 06-18-2002, 12:46 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
exhaust hangers
What do you guys do for exhaust hangers. I bolt mine onto the frame and then weld the bottom to the exhaust pipe so I don't have to use an ugly clamp. But then every time I go hot rod the truck the hangers break. It broke these two last night.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 06-18-2002, 01:24 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
Try welding a J hook to the top of the pipe and using a rubber hannger then another J hook.
You can buy the rubber part at autozone fore 3 $ and the J hooks you can make yourself.
Email me if you need a pic and I will get you one.
The problems you are having is that there is not enough play in the system and it will break when the engine etc moves under load.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 06-18-2002, 01:37 PM   #3
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
I agree with 68. You need something that has give. the exhaust system needs play to it cuz it vibrates, sways and all sorts of junk. i've got a j-type hook welded to the ehaust pipe then a rubber strip maybe 3/4" thick and 5" long it bolts to the hanger and to the frame, has appropriate play to it so it wont break or anything.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-18-2002, 02:27 PM   #4
Stout72
Not my good side.
Stout72's Avatar
It also grows in length when it gets hot, and shrinks when it cools. You need some form of a flexible mount to account for this.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 06-18-2002, 02:54 PM   #5
72chevyLWB
Got 20's????
72chevyLWB's Avatar
I had that setup on it before, but the rubber broke. Thats why I went to this type. The rubber one was welded on just like these, no J hook though. They looked like these here except a 3/4" thick piece of rubber about 2" long in the middle. I suppose bending some thicker steel for the J should be strong enough.
Old 06-18-2002, 02:55 PM   #6
Low69CST
Instead of welding to that hanger in the pic, why don't you just use some clamps like when you clamp on your mufflers to the exhaust pipe, thats what i'm gonna use, hopefully.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-18-2002, 03:56 PM   #7
Yellow Cheyenne
You may also want to check your motor/tranny mounts to make sure they aren't broke. If they are bad, they will allow too much movement and aggravate the problem.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 06-18-2002, 05:22 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Mine has racing wire holding up the muflers.
