Old 04-15-2002, 02:10 PM   #1
old_truck1969
old_truck1969's Avatar
Post 3/4 ton to 1/2
My latest lead on parts for my '69 is from my next door neighbour! It turns out that his friend has a 72 gmc and is looking for parts. He was looking at my uncovered truck (no box or front clip) and wants my rear axle. His 72 is a half ton. Will the two rear ends interchange? I am hoping to switch from the trailing arms back. I don't need a 3/4 ton anyway. Also, what changes do i have to make to the front suspension?
69 GMC 3/4 ton camper special, will have a '71 front clip (very long term project)
86 GMC 3/4 ton (daily driver)
Thunder Bay, Ontario, Canada
djbonazz@hotmail.com
[This message has been edited by old_truck1969 (edited April 15, 2002).]
"All Corvettes are red. The rest are mistakes." - John Heinricy
old_truck1969 is offline   Reply With Quote
Old 04-15-2002, 07:36 PM   #2
69 longhorn
Post
The rear diffs should swap(both coil im guessing). The track bar,& frame brackets are different from 1/2 to 3/4,so you need to swap them also. On the front,to convert to 1/2 susp,you need to replace the lower a arms(use 71-72),& balljoints,& you can bolt the spindles on. Also go for the 71 up tierod assys,& you may have to change the center link(again 71 up). Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-16-2002, 08:27 PM   #3
67Blacksheep
Post
Old 69-
I'm in the process of the conversion right now. All the parts mentioned above need done. Even the frame mount for the tracking bar! They are different between the two. Early classic sells a real nice adjustable panhard bar, but the mount I suppose is purely a junk yard item. It is the only thing holding up my swap. Sucks to forget a part when you buy all the rest!!! Good luck
'94 GMC Seirra Ext. Cab
'67 Formula Firebird
'89 GSX-R 750
67Blacksheep is offline   Reply With Quote
