Old 08-07-2009, 12:34 AM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Finally found some 15x8'' steel wheels
Well, sorry for a thread about this, but I am stoked that I finally found a set of 15 x 8" steel wheels for my truck rebuild. I happened to be traveling by a junkyard that I stopped by about 4 years ago. At the time they had a couple of military cucv blazers and I asked about the wheels then. The guy said $75 for 4 then, and I just couldn't swing it cause of college, but kept it in the back of mind. Well, today I just took a stab and went back by there. They have since went mostly into recycling metal, but I asked and they had a wheel rack and he pointed to a set of exactly what I was after. Sure enough, he had a set of 4 of the wheels and said, how about $20 a rim, well I said how about $75 for all, and sure enough, I got the set for as much as they quoted me 4 years ago. I am pumped, I have been wanting a set for awhile. Sorry for ranting, but it was a good deal. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-07-2009, 12:41 AM   #2
clos69
Its Topless Season!!!!
clos69's Avatar
Re: Finally found some 15x8'' steel wheels
....you know i had to
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 08-07-2009, 05:34 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if they still have that real thick paint on them (carc paint) then you'll need a fresh air respirator when you sand them.
I would recomend a pressure washer with a sand blasting attachment, and clean up the mess before the water dries up.
Old 08-07-2009, 07:31 AM   #4
71blksuper4x4
SWB 4x4 Collector
yeah, I will take some pics later today, but I am off for the junk- I mean treasure yards today to spend some quality time with my father. About the wheels, we will be sandblasting them to get the old Military Sand paint off of them.
TREVOR
Old 08-07-2009, 07:50 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Andy, do you have a specific company you might direct me to for the pressure washer sand blaster attachment?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-07-2009, 09:48 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I'm not Andy but I do have the info for you. This is the unit I bought and it works great! I blasted my frame and suspension parts with it. It can be messy because of all the water spray but there is no dust whatsoever.
http://www.northerntool.com/webapp/w...&issearch=2260
I got an old cat litter container (the large plastic container) and put a hole in the lid for the pick up and put my media in that. This way it is fairly sealed from water spray and doesn't allow the media to get wet.
Only complaint I have is the extension is a little too long and when attached to your power washer, it makes the overall length a little long. I am going to shorten it to fix that issue. Mainly need to do that if you have a very small area to blast in, which I do.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-07-2009, 04:58 PM   #7
Longhorn Man
thank you mike!
The carc paint is very bad stuff. I was never given details, but I was told that gettinly ONLY cancer, would be a good outcome.
It is more than just paint, it is supposed to hold up in a chemical attack.
Normal sandblasting is a very bad idea.
Old 08-08-2009, 09:56 AM   #8
jaros44sr
jaros44sr's Avatar
thank you mike!
Good info., never heard of that before. Is there a way to identify that carc paint, other then the thickness. What does 'carc' mean...carcenagen?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-08-2009, 05:59 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Pleeeeezzz Pictures!!!!!!!!!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-07-2009, 05:42 PM   #10
captainwillie
:d
captainwillie is offline   Reply With Quote
Old 08-07-2009, 06:07 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
I don't suppose they had any more sets of these wheels? Maybe a pair?
Keith
Convert to disc brakes.
Old 08-07-2009, 09:42 PM   #12
71blksuper4x4
SWB 4x4 Collector
lolife, I actually know a guy in missouri that will have a set of these for sale in a month. I will let you know around then, or pm me sometime in a month or so. Trevor
TREVOR
Old 08-07-2009, 10:16 PM   #13
TXRANGER
TXRANGER's Avatar
You guys need to post some pictures of these rims.
TXRANGER is offline   Reply With Quote
Old 08-08-2009, 06:13 PM   #14
Longhorn Man
i never knew what it stood for, but I know its nastyt stuff.
All army tactical vehicles are painted with it.
Old 08-08-2009, 07:55 PM   #15
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Chemical
Agent
Resistant
Coating
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 08-08-2009, 09:40 PM   #16
Longhorn Man
there it is!
I probably knew it at one point but since it didn't matter i never bothered remembering it. Heck, been almost 10 years since i walked away from it all.
