04-10-2010, 11:35 AM | #1 |
Swap question
Hey guys, I have a 62 GMC stepside. Someone offered me a good deal on a 78 Chevy that needs too much work to fix. It has a 350/TH350.
Is it possible to swap the front subframe and rear end into a 62? How much fab work would be required. Thanks for any help Ryan |
04-10-2010, 12:09 PM | #2 |
Resistance is Futile
Re: Swap question
Pretty much bolt on except for welding new axle perches and you may have to get creative with the motor mount stands. Also, I'm guessing, a trans mount will have to be made.
I'm sure others will add specific stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-10-2010, 12:46 PM | #3 |
Senior Enthusiast
Re: Swap question
Here's a link to a how-to on the front suspension swap:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850 And here's a link on the engine/trans mounts: http://67-72chevytrucks.com/vboard/s...d.php?t=369663
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-10-2010 at 12:47 PM. |
04-10-2010, 10:39 PM | #4 |
Re: Swap question
Thanks for the responses, and the links! I appreciate it.
Has anyone swapped a 78 rear end? |
04-11-2010, 12:27 AM | #5 |
60-66 Nut
Re: Swap question
The rear ends from '71-'87 are 1.50 inches wider than your original one. I'm going to assume that your GMC has leaf springs on the rear? If I remember correctly, there is about .50 inch difference between the spring pads from the '62 rear to the '73-'87 rear ends. You may have enough side to side movement with your springs to make this work without cutting and welding. However the correct way would be to move the spring pads to the correct location. The '78 rear end will have the shock mounts in a different location than the '62 as well. It would probably be easiest to move the shock mounts on the rear end to the '62 dimensions. Then there will likely be driveshaft and e-brake cable issues to deal with as well. IMO it would be a worthwhile upgrade to bigger brakes and likely better gearing.
04-11-2010, 12:36 AM | #6 |
fan of "Butters" Stotch
Re: Swap question
do it! Sorry for the image, I just couldn't resist! Does the truck run and drive? The parts for my last project all came out of a running and driving donor. Best thing I ever did; I knew everything was in good running order before it got put into the project. Also, no hunting around for parts at seperate places. Drive it come, and tear it apart in the driveway
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 04-11-2010 at 12:40 AM. |
04-11-2010, 01:22 AM | #7 |
Senior Enthusiast
Re: Swap question
You might want to verify exactly what rear end you have right now. My 1960 GMC short stepside originally came with a coil spring suspended Dana 44 rear axle. Some of the 3/4 tons came with Dana 60's. I'm not sure what was standard for GMC in 1962. The Dana 44 remains very popular in the Jeep and 4x4 community, so there are readily available gear sets and it's pretty beefy. I had my axles redrilled to 5x5 pattern, the axle stub turned down to fit the 5 lug 73+ brake drums, also added the later self adjusters. The Dana 44 has a very distinctive removable cover:
http://coloradok5.com/axleguide.shtml If you have a Dana 44 it might be worth keeping, and could turn out easier to convert to 5 lug rather than swapping out the rear end.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-15-2010, 07:43 AM | #8 |
Re: Swap question
Thanks for all the responses guys! I think I'm gonna do it!
04-16-2010, 02:20 AM | #9 |
Re: Swap question
Sounds great!!
just as marke01 mentioned, it may be easier to convert the rearend you have. Mine has a 12 bolt, and I may end up having Moser weld and redrill the axles. Regardless with what you do with the rearend, you can use the motor, tranny, crossmember, booster,ect
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
