04-12-2010, 09:07 PM | #1 |
did c-20's come stock with a sway bar?
ok i have a 66 c-2o, the A arms have 2 holes for a sway bar bracket(at least i think that's what they're for) but the frame has no mounting holes. what's up? the truck was partially disassembled when i got it so i don't know how it was originally. thanks fellas!
'66 c10ish straight 292 power! |
04-12-2010, 10:23 PM | #2 |
Re: did c-20's come stock with a sway bar?
I believe the 3/4 tons did come with one
04-12-2010, 10:45 PM | #3 |
My 66 C20 does not have one I think the sway bar was optional
04-13-2010, 03:44 AM | #4 |
sway bars were an option as dusty457 stated.
04-13-2010, 07:28 AM | #5 |
how then should i determine where to drill the holes on the frame?
04-14-2010, 12:59 PM | #6 |
Mount the factory sway bar at the lower A arms and it will land in the correct location on the frame rails. In order to properly install, you will also need the standoff brackets that are riveted to the underside of the frame rails and bolted to the sway bar.
04-14-2010, 05:32 PM | #7 |
cool thanks red! i see what you mean, i bought some standoff brackets for lowered trucks, who has good new rubber or is the poly better?
