Old 04-13-2010, 12:24 PM   #1
Barn-core
Barn-core's Avatar
Who's lowered more than 6" in the rear?
I've got 6" springs in the back of my '64 right now, and I've heard you can go as low as 8" with 2" blocks and a C notch before you hit the bed floor. I was just under my truck the other day though, and noticed that the drive shaft is already maybe within an inch of the top of the driveshaft loop in the trailing arm crossmember. So my question is, who has more than six inches of drop in the rear, and what mods did you have to do to get there? Thanks, Barn-core.
Barn-core, contra mundum with a vengeance!
"Our lady of blessed accelleration don't fail me now."
Barn-core is offline   Reply With Quote
Old 04-13-2010, 08:16 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Who's lowered more than 6" in the rear?
My frame has a C-notch and at full drop, my rear end housing rests up against the frame inside the C-notch. I have a sheetmetal rearend housing, which is flat on top of the center section, so I only had to raise my bed floor .750". This way I did not have to cut a section out of my bed wood to allow the center section of the rearend housing to poke through.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-13-2010, 09:48 PM   #3
Nailz
Shlong bed club
Nailz's Avatar
Hey Barn-Core i did CPP's grand slam drop. 7". 5" spings, 2" blocks. relocated shock mounts and trak bar. Also CPP notch. Rides good! Just scraping sometimes in and out of driveways.
Nailz is offline   Reply With Quote
Old 04-13-2010, 10:16 PM   #4
chris6499
chris6499's Avatar
cpp has a crossmember with a larger driveshaft loop to give more clearance and larger drop
chris6499 is offline   Reply With Quote
Old 04-14-2010, 10:57 AM   #5
Barn-core
Barn-core's Avatar
I'm more concerned about the driveshaft clearance than the bed floor. Has anyone gone lower than 6" without handing over their credit card info for new parts? Just wondering how others have modded their crossmembers for clearance.
Old 04-14-2010, 12:19 PM   #6
admiral grey bush
admiral grey bush's Avatar
Ive got 5" springs 2" blocks an notched an im sitting about inch or 2 from the bed. with no drive shaft issues.
admiral grey bush is offline   Reply With Quote
Old 04-14-2010, 02:35 PM   #7
spr85gmc
spr85gmc's Avatar
well then post pics Admiral welcome (Ithink 1 post since 2008). truck looks good.
spr85gmc is offline   Reply With Quote
Old 04-14-2010, 02:40 PM   #8
admiral grey bush
how?.. i been trying all day
Old 04-14-2010, 02:51 PM   #9
admiral grey bush
got it....
Old 04-14-2010, 02:55 PM   #10
Barn-core
Barn-core's Avatar
Thanks Admiral, great looking truck, that's the stance I'm looking for. How much drop up front, oh and what size tires are you running?
Old 04-14-2010, 03:08 PM   #11
admiral grey bush
front was cpp 3" springs an i cut 1 coil off an cut the bump stop mounts off too.. Tires up front are 225/60/15 rear are 255/60/15. I posted some other pics of a blue 66 long bed were gonna try 275/60/15 on the rear..
Old 04-14-2010, 03:09 PM   #12
chopper john
chopper john's Avatar
mine is a 1960 with an x frame
chopper john is offline   Reply With Quote
Old 04-14-2010, 04:21 PM   #13
admiral grey bush
notch pics
Old 04-14-2010, 04:24 PM   #14
admiral grey bush
Sorry tryn to get use to this
Old 04-14-2010, 09:47 PM   #15
shortbed70
shortbed70's Avatar
Im bagged all around dont know the amount but its low. I have no driveshaft clearence problems.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-14-2010, 10:11 PM   #16
likaroc13
Rollin' Old Skool
Originally Posted by admiral grey bush View Post
got it....
nice...love that stance
where'd you get your wheels, & what sizes are they? thanks
