Old 11-07-2011, 01:55 PM   #1
jimig1
jimig1's Avatar
Stock ride height 55.5
Anyone know what the stock ride height is of a 55.5 i forgot to measure what mine was before doing my MII front end and i want to see how much it dropped. the front of the step is what I measured from and it was about 10 inches I'm liking the stance it has
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 11-07-2011, 06:01 PM   #2
55metalmonkey
Re: Stock ride height 55.5
I'm curious myself, I measured mine before I did my sub frame swap but lost the notes I made also it was without eng/trans in. If I remember correctly it was 18.5" from the bottom of the frame to the ground but I'm just going from memory so it might be wrong
55metalmonkey is offline   Reply With Quote
Old 11-09-2011, 10:09 PM   #3
HiRMKin
HiRMKin's Avatar
I don't know if this will help you but my 59 measured 14" at the front of the step.
No motor or tranny
No front sheetmetal
Tires were 205/75/15
HiRMKin is offline   Reply With Quote
Old 11-13-2011, 01:14 AM   #4
55metalmonkey
No motor or tranny
No front sheetmetal
IMO that sounds about right since the frame sits a few inches higher than the door sill, out of curiosity I measured mine in the same place (after camaro subframe w/eng, trans & sheetmetal) and it's 8.5" I still have about 300lbs to go on which will likely drop it to 8"
Old 11-19-2011, 12:54 AM   #5
dicer
Okay, its a 58 3100, with P235 / 75B15 tires. At the seam like in the last picture its right at 14", with engine 235 and 3speed trans, missing the front bumper, I doubt the bumber weight will make a difference.
This was measured at the seam not the bottom like above. And since the above picture the edge looks bent down some that isn't a very accurate way to measure it. Using the above method mine would be at 12.5 ".
dicer is offline   Reply With Quote
Old 11-19-2011, 02:54 AM   #6
55metalmonkey
Thanks dicer
