Old 12-20-2010, 07:17 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
No frame vin numbers question
OK, I have a very original truck and was going to take it to get inspected in morning BUT I tried to find vin numbers by ps box on top rail of frame and I can't find any. I have 2 other trucks here and can find them on their frames. Its a 72 chevy truck, where are the other set of vin number on frame, I was thinking there was another set on top rail under cab but what side? Any help is appreciated. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 12-20-2010, 07:18 PM   #2
teeitup
teeitup's Avatar
Re: No frame vin numbers question
Sorry for bad pics but this is top rail by ps box
1980 chevy swb 4x4
Old 12-20-2010, 07:24 PM   #3
ebfabman
all the vin's I've ever seen have been on the drivers side, like you said by the ps on the top of the frame rail and on the frame rail under the cab.
ebfabman is offline   Reply With Quote
Old 12-20-2010, 07:25 PM   #4
redbaron69
redbaron69's Avatar
Randy the numbers are on the drivers side rail betwwen the front and back cab mount. may be impossible to see with the cab mounted to the frame.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 12-20-2010, 07:27 PM   #5
ebfabman
Randy I have had several trucks inspected here in NC and the inspectors never looked anywhere except on the vin tag. Do your inspectors know to look at places other than the vin tag on these trucks?
Old 12-20-2010, 07:29 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Ive never had an instance when they weren't there! does your DMV actually check frame numbers?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-20-2010, 07:36 PM   #7
teeitup
teeitup's Avatar
Well here in Kansas the highway patrol have checked the frame every time I had one inspected. They are now doing it at county sherriff's department and I know most of them over there so hopefully I can get it through BUT this is the Eagle truck and I would like to be able to say everything matches if I ever resale it. I've only had 2 other trucks in all my years not have one on frame one was a 67 gmc and the other was a 72 swb 4x4. I may have to try to get a mirror and see if I can find them under cab. Thanks Randy
1980 chevy swb 4x4
Old 12-20-2010, 07:52 PM   #8
KrazyRay
KrazyRay's Avatar
I usually see the vin by the steering box and the pass side under the cab. Many GMC trucks have no frame vin at all.
KrazyRay is offline   Reply With Quote
Old 12-20-2010, 08:11 PM   #9
sameyrasmea72
sameyrasmea72's Avatar
I have seen only one or two trucks that did not have the # on the rail by the PS. This is a 72 frame if it helps. You can barely see the #'s in the one pic.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-20-2010, 08:51 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
my 72 burb is missing the numbers on the frame.
Old 12-20-2010, 08:59 PM   #11
rusty baker
'70 C-10 Primer
rusty baker's Avatar
What kind of inspection is this? Kansas doesn't have a safety inspection. Is this some kind of rebuild/road worthy inspection?
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 12-20-2010, 09:05 PM   #12
chipflyer
chipflyer's Avatar
Any out of state vehicle that you try to register in KS has to be inspected and they are very picky.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-20-2010, 09:07 PM   #13
teeitup
teeitup's Avatar
Kansas does have a inspection for out of state cars and trucks when you want to title them in Kansas. They check vin plate, title, frame, spid label and build sheet if you have it. Vin, title and frame have to match.
1980 chevy swb 4x4
Old 12-20-2010, 09:08 PM   #14
teeitup
teeitup's Avatar
Thanks guys for all your help, I GOT LUCKY I found the one under the cab, very hard to read but it matches
1980 chevy swb 4x4
Old 12-20-2010, 09:13 PM   #15
chipflyer
chipflyer's Avatar
Good deal Randy, did you get a radiator and get her running? Make friends with the guys at the sheriffs office, I know of an old car from Nebraska that I might have to sell you cheap...
Old 12-20-2010, 09:15 PM   #16
Heck,"I've" never even checked any of my trucks for the numbers on the frame.I wouldn't know if any of the many trucks I've owned had the number or not.I know they were never checked and I thought Maryland was tough.They seem to care less on older stuff than late model.Good luck with it.It appears that some never got stamped.I know if they've been ground off (theft) the numbers will show up if you heat it with a torch.
It's amazing how different states are with this stuff.I just transferred a title to on a truck I have to Maryland from California at the DMV.The truck isn't even present.They just wanted a bill of sale and a signed title.Now I have a Maryland title and when I go to tag it it will be looked upon as an "in state" truck.
Old 12-20-2010, 09:18 PM   #17
chipflyer
chipflyer's Avatar
Kansas is tough, they consider anything from out of state stolen until the inspection proves it isn't.
Jeff
Old 12-20-2010, 09:50 PM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
My frame on my 72 Longhorn didn't have one stamped in it either.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-20-2010, 10:00 PM   #19
DANTIP
DANTIP's Avatar
The picture Jason has above was very helpful and was exactly where my number was. By the way the frame number was an abbreviated VIN. Rather than the full VIN (CCE142B######) it only has the last 8 characters (2B######).
DANTIP is offline   Reply With Quote
Old 12-20-2010, 10:03 PM   #20
truckdude239
truckdude239's Avatar
ebfabman is right here in nc all we check is the vin tag(on the body) but in nc any vehicle 35 years or older is exempt from inspections ( am an inspector in nc)
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-20-2010, 10:46 PM   #21
rusty baker
'70 C-10 Primer
In Missouri, you can buy a lifetime license plate for anythig older than 25 years. No inspection. Supposed to be historic with restrictions and supposed to carry a log. Had one for 15 years and never been checked. A local judge ruled that the restrictions weren't legal.
Old 12-20-2010, 11:53 PM   #22
teeitup
teeitup's Avatar
Every state is different. I've had a bunch inspected in Kansas. Once they are titled in Kansas, you don't have trouble dealing with Kansas, just pay tags and taxes every year. Unless you want a antique tag, pay for it once.
1980 chevy swb 4x4
Old 12-20-2010, 11:59 PM   #23
CORSAIR
CORSAIR's Avatar
Could any one of you nice Gentleman tell me were the number is on the frame of a 72 K-5?? I cleaned and painted the frame more than a year ago and I can't remember seeing a number???
"The Can't Family Lives Across The Street"
CORSAIR is offline   Reply With Quote
Old 12-21-2010, 12:13 AM   #24
teeitup
teeitup's Avatar
There should be a set right above ps box on top rail of frame right beyond the bolt hole where the PS hose clamp goes and another set on back in bewteen cab mounts on same side, see Samey's pic above for where that spot it
1980 chevy swb 4x4
Old 12-21-2010, 12:33 AM   #25
CORSAIR
CORSAIR's Avatar
Thank you, I will take a look as soon as it stops raining here in NV. The Pineapple express is in from the West and its been raining for 3 days thinking about building a ARK!! never get this much rain in So. Nevada
