01-07-2005, 03:28 AM | #1 |
Rear Pinion Angle??
Can you guys tell me what my rear end pinion angle is supposed to be?? I have a 71 LB 2wd. I am new to this truck stuff and just seems like it is pointing too far up. Thanks for the help, this board is great!!!!!
Later, Travis
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ) 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon |
01-07-2005, 05:20 AM | #2 |
The rear pinion angle doesn't need to be anything by itself specifically. It does need to be within 3 degrees of the angle as measured from the tranny. Here are some good links that show you how to properly measure it: 1 and 2. Three degrees is what most of the info I've read recommend. And you don't want 0 either as that can restrict bearing lubrication in the u-joint. Forgot 3 and 4.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
01-07-2005, 12:25 PM | #3 |
Here's another link that explains it, http://jniolon.clubfte.com/driveline...nephasing.html
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
01-27-2005, 08:06 PM | #4 |
I understand everything about the the pinion angle. I was just looking for the stock pinion angle for my 71 c10. somebody messed with it and has the pinion going way too far up. Just wanted to adjust it back to stock.
