05-19-2014, 01:21 PM | #1 |
VIN number not on dash?
I am in the process of restoring my blazer and as I replacing some of the decals, I couldn't find the VIN plate on the dash area... I have it on the body of the vechicle. (picture below)
but I would have thought that by 72 it would have it under the windshield area... is it missing?... and where exactly should this one be placed...my body shop guys cut it out before I documented it... and I don't exactly trust them to replace it in the same spot..
1972 Chevy Blazer Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=560741 |
05-19-2014, 01:31 PM | #2 |
Re: VIN number not on dash?
you will not find it , like the newer cars where you are thinking , it is only on the door jamb, and on spid if there on glove box , and frame by steering box , and one also under cab , , if 72 there will be a blue decal on door , by stricker , but they sometimes like spid get weathered or rubbed off , hope this helps
05-19-2014, 01:43 PM | #3 |
That does help...quite a bit.. thanks!..working on ordering a new SPID from chipflyer and I guess I'll have to find that blue decal too..... Hopefully I can find a pic of someones VIN and see about how far from the Striker it should be placed.. (it's a 72)
05-19-2014, 01:46 PM | #4 |
so did they remove that vin plate from the tub , its a big no no doing that are you changing bodies
05-19-2014, 01:48 PM | #5 |
the frame serial # is about 6 inches on driver side back from steering box , just past the bend up area for power steering pump , right on top
05-19-2014, 01:49 PM | #6 |
The Rockers were a complete disaster and the bedsides were replaced with the new ones that just came out...so during that surgery almost everything was removed..
05-19-2014, 01:51 PM | #7 |
I guess you would have to say I"m changing bodies.. New Doors, New Bedsides, New Rockers, (and everything around the rockers) ..etc..etc... New Floors..
05-19-2014, 01:55 PM | #8 |
This is passengers side... but it gives you an idea of what all had to be replaced..same on drivers side...basically the Core was really the only thing not invaded by serious rust.....and once I started, there was no turning back.
05-25-2014, 05:33 PM | #9 |
It will probably less of a hassle if you just put the plate back on when its done and not tell anyone at the DMV
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
05-28-2014, 01:25 PM | #10 |
IIRC mine still has the blue decal if your needing info on location.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
05-28-2014, 01:46 PM | #11 |
If you don't mind...my body guy said that he had the dimensions..but I would prefer to make sure...greatly appreciated.
05-28-2014, 03:06 PM | #12 |
I don't see where it's an issue. You're not attempting to commit fraud. I would rather have the original that matches the frame number welded in then another from a body that doesn't match. Stuff rusts. Stuff gets repaired.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-28-2014, 04:35 PM | #13 |
78K & 79C Jimmys
my 79 is a dash vin
my 78 still has it there but it looks different too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
