04-16-2015, 05:16 PM | #1 |
~Craig~
Security on a Budget?
Hi all,
So my living arrangements have changed. I live in a nice area but have limited off street parking. I have a new daughter; so to have someone install a nice alarm and kill switch just isn't in my current budget as I just finished my interior for the summer. So basically what I have been doing is pulling my coil to distributor wire and chaining the hood shut (Overnight and parking lots when I'm going to be a while) Other than being a PITA I'd say this is about as safe as I can get? The truck will turn over if someone tries to hot wire it but won't start... wont be able to open the hood to take a quick look. What are your thoughts or recommendations until I can get a true security system set up? This is on my 72 GMC Thanks all in advance |
04-16-2015, 06:23 PM | #2 |
Re: Security on a Budget?
put a toggle switch in somewhere between the ignition switch and power. That works
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
04-16-2015, 06:27 PM | #3 |
were are some good places to hide the switch. I've been thinking of this for a while but couldn't find a good place to hide the switch. and i don't want it just hanging or have to open the hood to get to it.
04-16-2015, 06:40 PM | #4 |
Old member
Do you have a bed cover on the truck? I would look at putting it under the bed lip are maybe in the front grille where you can reach it but no one else would know it's there.
04-16-2015, 06:42 PM | #5 |
my grandpa had his door open latch (shaved door handles with electronic button opener) under the truck on the stepside step lip and the rain water kept shorting it out.
04-16-2015, 06:44 PM | #6 |
I'm all for security and theft prevention. However, I think a lot of thieves know older vehicles are easy to add battery disconnects to, and as such makes it even more important to find a unique solution to hiding a disconnect.
Things that I've seen: One of the AM radio knobs as a disconnect. Switches wired in series that requires a certain combination. (a little bit much for my taste but effective) Switch underneath the drivers side inner fender Switch along the drivers (or passengers) frame rail, as well as at the rear of the vehicle behind a drop-down license plate frame. The problem with disabling features outside the vehicle is anyone casing your vehicle can easily pick up on any systematic steps you take Things like clubs and brake disabling devices may seem silly and ineffective, but the more trouble you create for a thief, the more likely they are to move on. It's the rare, professional car thief that is to be worried about. |
04-16-2015, 07:02 PM | #7 |
On my Z28 I had a switch on the clutch wire and was activated by my second button of the garage door remote. Car won't start unless the clutch is in.
69 Chevy 4x4 383 Power |
04-16-2015, 07:03 PM | #8 |
My wife bought me a train horn for the truck for our anniversary. I'm thinking about putting a switch on it so if you don't turn it off the horn will blast as soon as you try to start it. Figured it would scare them half to death and would send them running.
1969 Chevy c20(Miss Hackjob) |
04-16-2015, 10:11 PM | #9 |
On one of my trucks I put a keyed disconnect switch in my glovebox & installed a locking button on the glovebox door.
04-16-2015, 11:49 PM | #10 |
~Craig~
I like all of your ideas! I think it comes down to the fact that if someone wants it bad enough they will get it one way or another. The way I look at what I'm doing is the average person who thinks it will be a quick in and off with the truck, they get in, it turns over but wont fire... they go to pop the hood... they physically cant get it open.... lets say they do.... the odds of them having a coil to distributor wire is slim to none. Again this is just while it's sitting out over night and in parking lots. That is probably as safe as I can make it.
04-17-2015, 12:17 AM | #11 |
Consider the top-less Jeep solution. Steering wheel quick disconnect. Like said above. Make it difficult for the would be thief. More then likely to pass it by if they cannot steer it.
04-17-2015, 12:24 AM | #12 | |
04-17-2015, 12:28 AM | #13 |
That's what I did...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-17-2015, 01:35 AM | #14 |
There is a product called "brake jack" that locks up the brake from the floor.
Now I think I have the ultimate in "cheap security." I can easily remove my 3 speed on column shift lever and just take that with me. Back my truck up against an immovable object, leave in reverse, take lever, and walk. https://www.youtube.com/watch?v=Xm01YrbIYLs Last edited by In The Ten Ring; 04-17-2015 at 02:15 AM. |
04-17-2015, 01:39 AM | #15 |
Parts and more parts
Take the cigarette lighter and turn it into a push/pull (On/Off) switch. To me that is about the most useless item in the truck cab.
Frank |
04-17-2015, 02:18 AM | #16 |
04-17-2015, 08:09 AM | #17 |
I had a 64 nova I raced. to adjust solid lifters I put a toggle switch in line with the coil wire so it would'nt start when I was turning the engine over. Just hide the toggle. ( or, you could have 3 on the tree, no one today knows how to drive them..)
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-17-2015, 08:24 AM | #18 |
Nothing stops a roll back.
A 66 Mustang was recently stolen from a locked garage in my area.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-17-2015, 08:30 AM | #19 |
Not sure what your interior is like but in mine I have a folding forward bench seat. I but a fuel shut off valve behind the seat. As simple as folding the seat forward and turning the valve and the truck gets to fuel.
Mike
1967 SWB Small window Chev.....aka "The Skanky **tch" |
04-17-2015, 09:59 AM | #20 |
Great idea , make it a 2 way switch that diverts the distributor + to the horn , ashtray is a good place for the switch
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive Last edited by 67 chevelle; 04-17-2015 at 10:23 AM. |
04-17-2015, 10:50 AM | #21 |
that would be hilarious if you let somebody drive your truck and not tell them the switch is there lol
04-17-2015, 02:44 PM | #22 | |
Not to many people drive the truck but I know a few jokesters that might try to jump in and that would almost be worth it to leave the keys in it
04-17-2015, 03:38 PM | #23 |
04-17-2015, 03:52 PM | #24 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
04-17-2015, 05:17 PM | #25 |
Empty holster in the drivers seat
