04-18-2015, 07:02 PM | #1 |
troubleshooting drivetrain shudder
68 C-20
292 straight 6 3 speed standard The truck will shudder when coming from a dead stop, but ONLY when she is HOT. Sometimes a little, sometimes ALOT. The clutch is a fairly recent replacement, the rear wheel bearings are not that old, the U-joints and center support seem OK -- I'm stumped! Any ideas where to look? Thanks in advance! |
04-18-2015, 07:27 PM | #2 |
Re: troubleshooting drivetrain shudder
Did you surface the flywheel when the clutch was put in?
04-18-2015, 11:15 PM | #3 |
I will have to look at the service records regarding the flywheel-- The head gasket is leaking onto the bell housing -- I'm thinking this is the problem, but why only when hot? -- Thoughts anyone ?
04-18-2015, 11:19 PM | #4 |
Warped flywheel?
04-18-2015, 11:31 PM | #5 |
Could be...this is a high mileage, ex-farm truck --
04-19-2015, 12:17 AM | #6 |
Head gasket leaking!
What?? Coolant?? |
04-19-2015, 10:10 AM | #7 |
Sorry -- I meant the valve cover gasket -- oil getting onto the bell housing -- could be making it's way onto the clutch and flywheel?
04-19-2015, 10:42 AM | #8 |
04-19-2015, 09:50 PM | #9 |
Well, she needs a complete engine overhaul anyway, so it seems a clutch will be part of the plan -- thanks for your advice -- B.
