04-18-2015, 08:02 PM | #1 |
Power Steering converstion
Guys, I'm adding PS to my 70 350 stepper. I've dropped the manual box and am installing an AGR variable ration gearbox. What on the steering shaft do I need to replace and where can I source the parts? I have a MOOG PS pitman arm, so that should be sorted out. Its the column and how to connect existing to the gear box, that I could use some guidance on.
As always, gentlemen---thanks Lou
Figure out what you want--then figure out what you are willing to give up to get it. |
04-18-2015, 08:07 PM | #2 |
Re: Power Steering converstion
I know this doesn't help on the weekend but call AGR and see what they say. It looks like that box has a double D from the pic you provided. Maybe you need a Double D to a spline adapter. I am sure others on here have that box as they seem to be pretty popular boxes. I changed on of mine and used a later intermediate shaft but that doesn't look like it will help you. Jim
04-18-2015, 10:22 PM | #3 |
closer view of the spline connection on the gear box
04-19-2015, 12:14 PM | #4 |
Is the spline connector and the rag joint one unit one trucks that came w PS? Also, can I just use the intermediate shaft that came with the stock PS?
04-19-2015, 03:02 PM | #5 |
Ah, got it. Just need a different rag joint, one that has a 3/4 spline receiver.
04-19-2015, 06:41 PM | #6 |
The second pic looks a lot different than what I saw in the first. Glad you got it done. I didn't think I had ever seen one like what i said. Jim
