Old 05-29-2014, 06:44 PM   #1
81rado210
81rado210's Avatar
introduction
New to the forum, some great projects on the board. I've wanted a 73-87 since I was a little kid and finally got my hands on one a few weeks ago. I used to be a fabricator and worked for muscle car shops for about 7 years, I've restored more cars then I can remember and have done more ls swaps then I can count on both hands... It's about time I built one for my self... Hopefully I'll have my self a project thread up soon but I've got an 81 I've already lowerd it with spindles, springs, and a flip kit in the rear, Names Jeremy by the way..
81rado210 is offline   Reply With Quote
Old 05-29-2014, 06:46 PM   #2
81rado210
81rado210's Avatar
Re: introduction
Guessing I'll need a photo bucket to post pictures?
Old 05-29-2014, 06:56 PM   #3
81rado210
81rado210's Avatar
Re: introduction
Just realized I put this in the blazer section.. I've got a c10 if admin can move it... Thanks
Old 05-30-2014, 08:48 AM   #4
Cherub
Cherub's Avatar
Re: introduction
welcome
Cherub is offline   Reply With Quote
Old 05-30-2014, 08:06 PM   #5
walkerb
walkerb's Avatar
Re: introduction
Welcome!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 06-01-2014, 01:58 PM   #6
81rado210
81rado210's Avatar
Re: introduction
Old 06-01-2014, 02:03 PM   #7
81rado210
81rado210's Avatar
Re: introduction
Old 06-01-2014, 02:05 PM   #8
81rado210
81rado210's Avatar
Re: introduction
A few pictures from stock to how she sits now... The mags are hitting the lower control arms too much to just clearance so I will be picking up some 20's here soon, looking at running the mb oldschools right now
Old 06-01-2014, 03:45 PM   #9
81rado210
81rado210's Avatar
Re: introduction
A couple pics of the home brew flip kit, picked up the perches for 10$ and had some shocks laying around from another project that fit perfect, had to set pinion angle but other wise pretty straight forward install...
Old 06-01-2014, 03:51 PM   #10
81rado210
81rado210's Avatar
Re: introduction
Decided to go ahead and shave the filler neck from the secondary fuel tank today... I'm a little rusty but it turned out okay... Theres some pitting around where the neck used to be that I'll have blast before body work and paint but I just threw some primer on it for now...
Old 06-01-2014, 04:25 PM   #11
rusty76
rusty76's Avatar
Re: introduction
Welcome aboard. Looks like a very nice truck!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-01-2014, 04:43 PM   #12
flashed
Re: introduction
Welcome from a little ways up the road ,nice truck.
flashed is offline   Reply With Quote
Old 06-01-2014, 07:04 PM   #13
bigd65
bigd65's Avatar
Re: introduction
I thought about a flip kit but didn't want to mess with the notch..... Fantastic looking truck there.... Love the black
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 06-01-2014, 07:33 PM   #14
81rado210
81rado210's Avatar
Re: introduction
Thanks guys!
After removing the bump stops and brackets the truck actually has a good 4" of clearance between the axle and frame, the exhaust even clears... If I go any lower I'll have to look into a notch but otherwise she's fine with out one..
Old 06-03-2014, 09:57 PM   #15
81rado210
81rado210's Avatar
Re: introduction
It's looking like I've got one of my projects sold so hopefully I'll be picking up some wheels and tires this weekend..
Old 06-03-2014, 10:03 PM   #16
81rado210
81rado210's Avatar
Re: introduction
Anyone have experience with discount tire? I'm looking at the mb old schools but they are special order and I'm not sure how long it would take to get them... If it's too long I I may just go to summit, they are only about an hour and a half away...
Old 06-14-2014, 11:50 AM   #17
81rado210
81rado210's Avatar
Re: introduction
Old 06-14-2014, 11:55 AM   #18
81rado210
81rado210's Avatar
Re: introduction
Been busy but I did pick up the wheels last week and got some work done on her. When I ordered my drop spindles I measure the passenger side rotor and it was 1.25" but mid install I realized the other side was 1" in the end it turns out everything but the passenger side spindle and rotor was a 1" setup so I had to replace onerotor, both calipers and even the brake hoses... Nothing was in stock pain in the ass but everything is new now and I'm done with that ordeal...
Old 06-14-2014, 02:11 PM   #19
Zane M
Re: introduction
The project is turning out great so far!
Zane M is offline   Reply With Quote
Old 06-14-2014, 07:00 PM   #20
81rado210
81rado210's Avatar
Re: introduction
Thanks!
Old 06-14-2014, 07:31 PM   #21
81rado210
81rado210's Avatar
Re: introduction
Decided to pull off the chrome rails today, welded up the holes and the twenty other holes from god knows what that had been drilled over the years... While I was at it I decided to shave the stake holes cause I sure as hell won't be needing them...
Figured I would do a little step by step for anyone that may be new to welding or just curious...
First I cut out some filler panels...
Then I tacked in place side to side then the corners making sure to keep it flush along the way...
Then finish weld, I welded this different then your typical filler panel in two ways. First, I welded it a little hot since I was using 18 guage and the bed rails are two layers with a rolled lip around the stake pockets so I wasn't worried about warpage. Second, I welded it a little fat to fill in the low spots from the rolled edge...
Next I ground it smooth with a flap disc making sure to keep it flat and keep it on the weld. You do not want to grind the metal thin. Then finished it off with an orbital sander....
Next I just threw some spray can primer on there till I'm ready to strip her down for body work and paint...
I've got some perfect match paint in a spray can I'm going to throw on there just to keep her looking shiney till I'm ready for body work I'll post some pictures of the whole truck minus the chrome rails and stake pockets later...
Old 06-14-2014, 07:35 PM   #22
81rado210
81rado210's Avatar
Re: introduction
I may be picking up a wrecked Tahoe tomorrow for the ls swap so this progress may start coming sooner then expected...
If an admin could move this to the project thread and change the title to 81 swb build or what ever seems fit for it I would appreciate it
Thanks, Jeremy
Old 06-14-2014, 08:55 PM   #23
81rado210
81rado210's Avatar
Re: introduction
Done for now...
Old 06-14-2014, 09:15 PM   #24
andrewmp6
Re: introduction
What year is that white old ford in the garage?
andrewmp6 is offline   Reply With Quote
Old 06-14-2014, 09:20 PM   #25
81rado210
81rado210's Avatar
Re: introduction
79
