Old 03-19-2004, 12:36 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
HELP!! CARBURATION PROBLEM!!!!Need help ASAP!!!
i was driving my truck tonight and all of a sudden it starts trying to stall out so i drop it down a gear to get the revs up and after i turned off the main road i look back and it is blowing lots of black smoke out the pipes then i stop and it stalls out and i have a hard time getting it to start again and rev it up to 4000 and it is running really rough so i have to put it in drive at high rpm to keep it from stalling out. what is wrong???
sorry for the long post. i just need to try to get is fixed tonight because i need it to get to school tomorrow and it is my only ride.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 03-19-2004, 12:41 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My blazer did that a couple of day's ago when I got arco gas (which I never buy) and as soon as I ran out the old gas and put in new gas it ran normal.. Sound's like you got a rich condition though..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-19-2004, 12:44 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
black smoke is running to rich, either stuck choke or a stuck float.
sneakysnake is offline   Reply With Quote
Old 03-19-2004, 12:45 AM   #4
71chevylongbed
Got Horsepower?
every time i fill up i get gas at the same station and at the same pump every time. i filled it up full a few days ago and have already used half the tank so far without any problems until now so i don't think the fuel is the problem.
Old 03-19-2004, 12:46 AM   #5
71chevylongbed
Got Horsepower?
the choke is open. how do i check for a stuck float?
Old 03-19-2004, 01:16 AM   #6
Maximum Overdrive
December 21, 2012
If your float is stuck you can try tapping the carb gently with the handle end of a screwdriver. That can help if a float is stuck.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 03-19-2004, 01:50 AM   #7
71chevylongbed
Got Horsepower?
the problem was a stuck float. i tapped on the carb and the problem went away. what would cause the float to stick in the first place and how can i prevent it from happening again.
Old 03-19-2004, 03:21 AM   #8
phestus
Likely the cause of the " stuck float" (causing way too much gas) is just one tiny wee speck o' dirt, somewhere in the carb that just loves to get in with the float valve and seat..(causing you way too much aggravation)..
Sooo. to prevent this, as long as you're comfortable with the procedure, is to take apart the carb, and minimum, clean out anywhere where gas is coming into the carb and going into the float chamber..Do yorself a favor and get the kit and rebuild the carb..
Other culprit for dirt is old fuel filters..
And last but not least, a float that don't float no mo'...I've heard of this, but never actually seen it...Pull your float, toss it in a jar of gas..If it floats, it likely works..With old copper hollow floats, I guess some of them could spring a leak, but....
Hope this helps..
'70 C-10, mostly rust n' dust
'74 BMW R90/6
"The quickest way to get yourself out of a hole, is to stop digging..."
phestus is offline   Reply With Quote
Old 03-19-2004, 03:24 AM   #9
Sweet72
Sweet72's Avatar
It may have been just some dirt in the fuel that became lodged between the needle and seat (the float controls this valve) causing it to run rich. To avoid this problem in the future, make sure you have a good fuel filter installed in the feed line either before or after the fuel pump. You may also want to check the condition of your fuel tank and pickup tube/sending unit sock as it may be corroded and sending trash to your carb.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-19-2004, 07:34 AM   #10
I'd also check for a vacumn leak. Just went through that on my 82. The vacumn hose to the tranny decided to give out on me.
Palf70Step is online now   Reply With Quote
Old 03-19-2004, 10:56 PM   #11
Gordo
Thumbs up
phestus speaks words of wisdom!
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 03-20-2004, 02:28 AM   #12
MAC67
" SHOW ME"
MAC67's Avatar
yup , im runin a 780 holley , her teeth aint big enough to chew up the big chunks hahaha , sounds like you had a chunk suck in the needle n seat , is its a holley you can clean the bowls while its still on the car , just take up the float level screw and pull youre needle and seat , before you do that tho be sure and lark youre float level where they are currently set before you remove them, or dont and just reset the float levels,, any ways hope it helps
MAC67 is offline   Reply With Quote
Old 03-20-2004, 02:38 AM   #13
71chevylongbed
Got Horsepower?
it is an edelbrock and i'm running a filter right before the carb. it ran alright today so i probably won't worry about it unless it does it again.
Old 03-20-2004, 02:44 AM   #14
MAC67
" SHOW ME"
MAC67's Avatar
yeah you probably just passed a chunk of crud , edelbrocks is a pretty trouble free carb , doesnt require near the upkeep a holley does , and holleys are horrible ofr sticking a float
