Old 06-06-2006, 10:45 PM   #1
68Stepbed
68Stepbed's Avatar
Smooth firewall pics
I plan on running aftermarket A/C on the 68. I need to see pics of smooth firewalls with the heater box removed. I need to see how to cover up the ugly hole for the blower motor.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-07-2006, 10:09 AM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: Smooth firewall pics
I did the same thing.
I made a plate to cover it up. I was going to use 2, one for the back round hole, then one for the front, but I just use one large one.
Here's a pic. I may mount it a little differently, and probably paint it to match. This was done in a hurry before a show while in the middle of my A/C install.
http://www.slickorange.com/Album/ima...gmc_image1.jpg
There's a couple of other pics it shows up in too in that album...
http://www.slickorange.com/Album/1971_gmc_index.html
BTW - This was an afterthought pretty much. I had a factory A/C setup installed - otherwise, I probably would have done something more permanent.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-07-2006, 02:23 PM   #3
Mine is not done yet, but I cut out some patches for the openings and welded them in. I have the fan opening, clutch opening and the other unneeded holes roughed in now, but no pictures yet.
I hope mine looks as nice as Yank's (last picture) when I'm finished
Old 06-07-2006, 03:26 PM   #4
Shane
Shane's Avatar
here's mine ... this was taken over a year ago and sadly the truck looks the same ... no progress.
Shane is offline   Reply With Quote
Old 06-07-2006, 04:12 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Here is mine. I added a piece to the weird curve where the blower motor sat, so it would have the same outside curve as the other side. I also cut out both holes and welded in a single piece of sheetmetal.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-08-2006, 11:03 PM   #6
greasemonkey
greasemonkey's Avatar
I shaved the wiring gutter along with the heater holes, lots more work but to me it looks good.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-09-2006, 12:10 AM   #7
glock35ipsc
Greasemonkey - That looks sharp! I may have to finish mine off like that too.......
Bob
Old 06-09-2006, 12:30 AM   #8
pumpkin
pumpkin's Avatar
That is sweet
pumpkin is offline   Reply With Quote
Old 06-09-2006, 04:18 AM   #9
Wootdog
Wootdog's Avatar
When you guys add the a/c, what will the hole look like? I dont have pics here with me, but the cutout I have is about four inches long and two inches high. Previous owner filled in the hole made the afore mentioned one and installed a plug with four connections, but never installed the a/c. I think it is for old air but not sure. I will post pics in a few days. Have to get back to the states first. Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 06-09-2006, 10:03 AM   #10
Orange
Licensed to Thrill!
Orange's Avatar
Greasemonkey - that looks great man - I love it!
If mine had been what it is now from the start, then I would have wanted to take the route that you are going.
Old 06-09-2006, 10:07 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you gonna do it make sure to add the rounded corner piece it just looks incomplete with out it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-09-2006, 12:43 PM   #12
68Stepbed
68Stepbed's Avatar
That's the reason I wanted to see pics. I thought it might look unfinished also. It looks good either way. I was thinking of leaving it like it was and mounting my bulkhead fitting where the blower motor was.
Matt
Old 06-09-2006, 01:20 PM   #13
hd78glide
hd78glide's Avatar
I don't understand. What part is the "rounded corner piece"?
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
hd78glide is offline   Reply With Quote
Old 06-09-2006, 01:43 PM   #14
glock35ipsc
Here is mine in the raw, and I circles the spot on the orange truck.
Bob
Old 06-09-2006, 02:04 PM   #15
hd78glide
hd78glide's Avatar
Cool, thanks...
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-09-2006, 02:53 PM   #16
mocwon
Keep On Truckin'
mocwon's Avatar
I took the little hump out that's circled in red on glock35ipsc firewall since I didn't see a need for it with the Vintage Air set up.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-09-2006, 03:04 PM   #17
glock35ipsc
Hmmmmm, I like that...... :}
Bob
Old 06-09-2006, 03:21 PM   #18
hd78glide
hd78glide's Avatar
I like it. I really like the idea of a smooth firewall. Do you lose your glove box with vintage air?
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 06-09-2006, 04:12 PM   #19
68Stepbed
68Stepbed's Avatar
Good question hd. I forgot about asking about that.
Matt
Old 06-09-2006, 04:33 PM   #20
76bonanza
76bonanza's Avatar
Shane what kind of headers you running are the 3/4 length? Any other pics of you exhaust?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-09-2006, 09:12 PM   #21
Rokcrln
Rokcrln's Avatar
No you do not loose the glove box but they give you a new liner that is not as deep if I remember right. My kit has been in a box for about 4yrs now One qiestion I do have (to lazy to go into the attic and look) is do you need to mount the fire wall conection at that point or can you mount it any where and just run more line?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-09-2006, 10:54 PM   #22
XXL
Seņor Member
XXL's Avatar
Much shaving...
XXL is offline   Reply With Quote
Old 06-09-2006, 11:01 PM   #23
mocwon
Keep On Truckin'
mocwon's Avatar
Kevin
LFD Inc.
There is "some" choice of where to poke the lines through the firewall but not much. Using this type of bulkhead fitting limits how much it can be moved around.
Just Passin' Thru
Old 06-09-2006, 11:02 PM   #24
trucky72
trucky72's Avatar
Off point question here maybe, but how many different manufacturers are there with this vintage air conditioning fit? are their a couple to choose from? Can I get some company names to search?
trucky72 is offline   Reply With Quote
Old 06-10-2006, 09:09 AM   #25
bagged74
its just $$$$$
bagged74's Avatar
vintage air, hot rod air, old air products, and airtique are a few of the different manufacturers.
bagged74 is offline   Reply With Quote
