Old 06-07-2006, 06:38 AM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
My progres pics, finally!
Stated the bodywork on my truck to get it through its annual inspection as the rocker rust would have failed it. Front end half stripped down for access. I've also removed the remains of the back half of the exhausts and have dropped them in to a local exhaust place to have two new ones made up. Should be ready today with a bit of luck.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-07-2006, 07:16 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: My progres pics, finally!
Good luck with the rust removal.....
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 06-07-2006, 10:23 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Never heard of a rusty rocker causing an inspection problem - that is interesting. How much rust is too much to pass your inspection?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-07-2006, 10:42 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
If theres more than surface rust (i.e. it holes when they hit it with their little plastic inspection hammer or it's already holed) within 15cm of what is considered to be a structural member such as a cab mount it'll fail. This rule is really designed around modern monocoque vehicles and doesn't really take into account older vehicles with a seperate frame, so it means regardless of the fact this rust doesn't really effect the structural integrity of the vehicle it still fails. the government over here has been tightening up and tightening up the rules with the aim of taking older vehicles off the road. Fortunately anything made pre 1972 is only tested for visible smoke rather than emissions. In the 22 years I've been driving its changed a lot, in the past I've had cars pass with exhausts patched with coke cans and two pipe clips, gaping holes in the fenders, even patches pop riveted on over holes.
Phil
'67 C10 long fleet.
Old 06-07-2006, 02:15 PM   #5
Sounds like Pennsylvania. Japan was real rough on inspections too. Good luck with the clean up of the truck. I think it even looks sharp half stripped!
Old 06-07-2006, 02:19 PM   #6
silvertonguedevil
silvertonguedevil's Avatar
Interesting. My truck would've been in the junk yard a long time ago then.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 06-09-2006, 11:32 AM   #7
Lippyp
English Chevy Owner
Lippyp's Avatar
Yeah it's got a bit silly really! Just been to pick up my new exhaust bits. Two matching 2 1/2" pipes to go from the mufflers to just in front to the rear wheels, I've just got to check them for length and take them back to have the ends stretched and the 3" stainless tips welded on. These things are really heavy gauge steel so should outlast the rest of the exhaust which is a little rusty. the idea is when the front bit dies I'll maybe go to headers and a decent set of louder mufflers.
Phil
'67 C10 long fleet.
Old 06-09-2006, 01:22 PM   #8
HeavyD
HeavyD's Avatar
Up here we are starting to have on-the-spot inspections, and they will fail you if any rust holes are present. Guy I know has a pretty nice 71 GMC and he has a small hole in a cab corner. Now he has to fix it or the truck is illegal to drive. Lippy are you planning to keep the yellow color on your truck?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 06-09-2006, 05:03 PM   #9
BigSky71
LAIDOUT
BigSky71's Avatar
Wow, that is really aggressive enforcement. The downside I see is people doing very bad bodywork and paint to cover up any holes so they can get their vehicle back on the road.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 06-09-2006, 07:05 PM   #10
HeavyD
HeavyD's Avatar
It doesn't happen alot, but just latrely they have had these get-em-off-the-road blitzes. Hope they are done for awhile.
Old 06-10-2006, 04:05 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
Yep, yellow is staying for the moment as I can't afford a full repaint. We also have on the spot inspections, both forr vehicle condition and also now for emissions.
Phil
'67 C10 long fleet.
Old 06-10-2006, 12:01 PM   #12
Lippyp
English Chevy Owner
Lippyp's Avatar
Got the rest of the sill off today and found that the bottom of the door pillar is rusted through which is a bummer as I don't have the repair panel for this bit. They do make them though so I guess I need to order a pair as like as not the other side will be goosed. $19.95 each and I'll have to spring for air freight as surface will take too long. What is the best way to make sure that this all lines up properly, any tips appreciated. Do I do the kick panel patch first and then the door pillar and then the inner rocker?
I started to dress down the old spot welds on the rear of the sill and test fitted the sill just for a giggle, not a bad fit but will need a bit of work for a good fit..
I also took my new exhausts and test fitted them so now they're all marked up to go back and have the tips welded in and the box end needs to be stretched so it fits over the box outlet.
Phil
'67 C10 long fleet.
Old 06-10-2006, 12:05 PM   #13
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I like the yellow, and I am surprised the rocker backing plate is in that good a shape! Looks like other than some surface rust, your floors and rockers weren't in that bad a shape at all. Especially for a truck that was shipped over there! Usually the trip causes lots of rust. Keep us updated on your progress. Looking good! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-10-2006, 01:02 PM   #14
Lippyp
English Chevy Owner
Lippyp's Avatar
Thanks, the floors gonna get a going over with a wire bursh in the angle grinder followed once the repairs are done by a coat of POR15 before the new carpets go in.
Phil
'67 C10 long fleet.
