Headlight issue
I just hooked everything up tonight to check my head lights, signals, blower etc... I have one head light that operates perfectly and the other one is dim. My initial thought was a bad ground but then I hit the high beam switch and the light went out. Any ideas? I'm stumped
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Re: Headlight issue
Have you checked the connections at the dimmer switch? I also suspect a bad ground. It could be both issues at play here.
58 Apache short fleetside ona 64 chassis: ![]() |
Re: Headlight issue
I got her figured out, it was a bad ground after all. I made a jumper wire and tested other spots and came up with a solid ground. Everything electrical works the way it should now, I'm pretty happy seeing how this was my first wiring experience. I got some great pointers from by buddy Rick on how to route everything, thanks again bud.
