02-22-2005, 03:33 AM | #1 |
'72 c10 half ton and '72 c20 three quarter ton
I have '72 custom deluxe 10 half ton. I'm looking into getting a '72 custom deluxe 20 three quarter ton with no motor or trans. Whats the difference between the two trucks? Can I interchange body parts etc.
Also my frame in the c10 is rusty and has a couple of holes in it , Whats the best way to fix it. |
02-22-2005, 04:08 AM | #2 |
There's a lot of things different between 1/2 ton and 3/4 ton chevy trucks; 72 or earlier. Heavier frame, heavier suspension parts, heavier duty springs or leafs, and added reinforcement to specfic parts like trailing arms for a coil sprung rear-end. Also, the rear-axle, it's gear ratio, and the lug pattern for the wheels.
Above this are the options, which include transmission and engines, overload springs, towing packages, camper packages, etc.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
02-22-2005, 04:25 AM | #3 |
body parts are the same.
72 GMC sierra 3/4 ton 402 bb 68 GMC 3/4 ton 2010 camaro rs: daily driver |
02-22-2005, 08:42 AM | #4 |
Watch out for your cornhole !
I'd never consider fixing a frame with holes rusted through it. Frames are super easy to come by. Just look on the parts board, they're on there all the time.
02-24-2005, 01:05 AM | #5 |
i plan on fixing up the c10
