![]() Join Date: Oct 2007
I have a non-tilt steering column that has play inside. The outside does not move at all. I have a 1967 C10 and have some manuals but none of them show a complete break down. I would like to rebuild my column and install as many new parts inside as possible. Does anyone have a good diagram of this column? Thanks.
Re: Play Inside Steering Column
That's a solid shaft all the way down to the flex joints. Either the flex joint or the rag joint must have play or your steering wheel is loose. Those aren't hard to rebuild especially if it,s a floor shift.
Thanks for the tips, I just have the feeling I
'm biting off more then I can chew. |
at the bottom of the column there should be a small spring and washers right at where the column connects if it is missing it wont keep the proper tension on the column shaft and lower bearing causing slop in the column
I am a Referee of life.
There are bearings at both the top and bottom of the column(IIRC).There should be a write up in the FAQ section but I haven't searched it.Check your local library for other manuals that may have a breakdown on this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
