455 Oldsmobile
Not like my ADD shop doesn't have enough going. I'm in the middle of a engine build for my Cutlass. Just got the heads back tonight. Time to start a thread!
"I feel the need for speed!"... as soon as I am done with my nap. |
Post Whore
![]() Join Date: Feb 2000
Re: 455 Oldsmobile
I've got a 455 Olds in my 80 Trans Am so will be interesting watching this thread. My motor appears to be very tired. What all are you doing to yours and what numbers are you expecting?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: 455 Oldsmobile
Well I'll start with the heads they are C's which had hardened exhaust seats
The way I got them. I had larger 2.07 SS intakes installed and stock exhaust valves. Back cut valves and some mild porting. Smoothed the EGR bumps and tear dropped the valve guide bosses. Running a Engle cam JM 20-22 that has .496/.512 lift. 266/274 adv. duration 226/230 @.050 on 110* lobe center Had the machine shop balance it, install ARP main studs. Already had ARP rod bolts when I got it. Still need to degree cam. Get a fastener kit, gaskets, and figure out my oil pan. Mod one myself or find some cash for a deep sump moroso/milodon ? Might add an accusump for extra protection. Similar builds have seen about 380HP 500+ lf lbs. with W/Z manifolds. I'm on the fence about running headers. (getting old ![]()
Post Whore
Re: 455 Oldsmobile
Sounds great - really like those valve covers. Looks like enough trunk to fit a SmartCar - I like it!
Re: 455 Oldsmobile
Where did you find the valve covers? I Love them
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#6 | |
Re: 455 Oldsmobile
Later someone asked me if I had to have a fog horn. ![]() Covers came with the car, package deal.
Re: 455 Oldsmobile
I am also curious, have you chosen pistons yet?
Re: 455 Oldsmobile
Sorry thought I put that on there. .030 SP 2278P forged not the best out there but not a high rpm screamer so they will do fine. And they came with the car!
Re: 455 Oldsmobile
I was just curious because I recently rebuilt my 455 very similar to what you are doing, but mine is stock dish pistons and stock cam still (.440/.440 Lift).
Re: 455 Oldsmobile
Never seen Gold turned to Silver before....
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: 455 Oldsmobile
? Not enough coffee? I'm missing it. explain?
#16876
Re: 455 Oldsmobile
I think he's suggesting that the block should be gold not silver.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#13 |
Re: 455 Oldsmobile
I did mine in gold, once its complete its a pretty overwhelming color
#14 | |
Re: 455 Oldsmobile
gold and bronze not silver that I know of but who cares mine is gray. ![]() All the good (matching) Olds paint are special order and cost too much. I had it boiled down to red or blue until I saw the can of cast iron gray. That I just had to have. I'm happy with it.
#15 |
Re: 455 Oldsmobile
I like it gold with oem valve covers, yours looks great. I did not think the polished valve covers would look as good with gold.
#16 |
Re: 455 Oldsmobile
Thanks. I agree with you on the polished valve covers. I don't know how close my gold is to the original Olds gold paint because I just used the only gold engine paint I could find. I originally wanted to use taller valve covers so I could use roller rockers, but I went with stock valve covers and stock rocker arms for now since I left the stock cam in it.
#17 | |
Re: 455 Oldsmobile
#18 | |
Re: 455 Oldsmobile
Pretty sure my 70 Cutlass had a gold 350, that was many years ago.
#19 |
Re: 455 Oldsmobile
I believe from what I read about Olds engine colors a while back that 455's of any year were never painted gold. I think it was only the 350's.
#20 | |
Re: 455 Oldsmobile
Could be. The only factory 455's I have seen were from post 75 when they all went blue. I did see a rebuilt 455 in a 442, it was gold but far from factory, so it really doesn't count.
#21 |
![]() Join Date: Mar 2005
Re: 455 Oldsmobile
That is going to be one cool Olds. And from the engine specs you provided, it'll haul butt, too!
I think those 'Vette wheels look pretty classy on there. You don't see those too often.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#22 |
born to lose
Re: 455 Oldsmobile
I swear I've seen a pic of that car burning the tread off those tires before....
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
#23 | ||
Re: 455 Oldsmobile
http://youtu.be/fPZtCZWASPU No updates on the 455. All I have done is ordered my gasket set and engine hardware. Still have to degree the cam and get ARP headbolts.
#24 |
Re: 455 Oldsmobile
Anyone put Headers on these old motors. I got Gold 403 I stuck in 66 C-10 but can't seem to find headers that will fit. Any suggestions?
#25 | |
Re: 455 Oldsmobile
I think headers are discussed here. http://67-72chevytrucks.com/vboard/s...d.php?t=452193
