04-03-2013, 11:28 AM | #1 |
Custom driveshafts
Who is everyone using? I've called Denny's and Inland Empire and got two differnt opinons on transmission yokes. Who should I go with?
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
04-03-2013, 02:25 PM | #2 |
MOTORHEAD!
Re: Custom driveshafts
Mark Williams Enterprises
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
04-03-2013, 04:35 PM | #3 |
It's Better With Nitro
I tend to use Mark Williams for my race car driveshafts - solid, aluminum and carbon fiber. For my hot rods/street driven cars, I use a local shop. What trans yokes are you considering?
04-03-2013, 04:58 PM | #4 |
meowMEOWmeowMEOW
As a weekend warrior only making about 40X horsepower, I had a local shop make me a "performance" driveshaft; a tiny bit thicker wall and better quality steel with the HD u-joints (no zerg fitting). Its a tiny bit heavier than stock (like a pound) but holds the power great and was a bargain at only $130.
04-03-2013, 09:32 PM | #5 |
Registered Truck Offender
A 3rd for Mark Williams on the track
I built a mild El Camino show/driver and used Dynotech. They build a nicely priced $275 street driveshaft with free shipping., DOM steel, Chrome Molly shafts a little higher
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 04-03-2013 at 09:42 PM. |
