Old 01-31-2010, 07:39 PM   #1
gkesseru
gkesseru's Avatar
Control arm bushing install?
I am rebuilding the front end of my 68 C10 stepper with a complete swap from an 81 step. I have totally disassembled the 81 front end. I have removed the bushings by burning out the rubber and crushing the leftover bushing tubes. Do the new bushings have to be pressed in, or can they be driven in just by tightening the bolts on the end of the control arm shafts?
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 02-01-2010, 09:57 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Control arm bushing install?
They need to be pressed in - your local machine shop or body shop should be able to take care of it for you
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
