Old 01-31-2010, 10:00 PM   #1
67vetteal
72 L/B, Noisy 12 Bolt
I need to be educated on my trucks Differential. It's singing and I know the Ring and Pinion are not aligned due most likely the Pinion Bearing. What year Carriers will fit the present Housing? Thanks in advance, Al W.
67vetteal is offline   Reply With Quote
Old 02-01-2010, 06:18 PM   #2
67vetteal
Re: 72 L/B, Noisy 12 Bolt
ttt
Old 02-01-2010, 08:24 PM   #3
LONGHAIR
The carrier is not necessarily a problem...but if the bearings are shot, the ring and pinion definately are too.
I always recommend seeking the services of a professional. The set up of the gears is a very precise task. It takes some special tools and a lot of patience. It's just not worth the hassle/headache/expense for a jod that most guys will only ever need to do once.
Pay a pro and you will get a warranty too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-01-2010, 08:30 PM   #4
67vetteal
OK, I understand. Point well taken. I'd like to go Posi. Any advice as to what kind of unit I can replace the current one with? (Years and Truck Specific, etc.) If I'm paying for a rebuild I might as well go for the Posi. Thanks, Al W.
