Old 10-19-2012, 09:58 PM   #1
trivon56
trivon56's Avatar
Gauge needles
Does any one know of a site that sells gauge needles for an 80 c10 or know of any interchangeable parts for the gauge needles. Thanks a lot.
trivon56 is offline   Reply With Quote
Old 10-20-2012, 08:56 AM   #2
Ski-me
Ski-me's Avatar
Re: Gauge needles
Which ones are you looking for? It might be easier to hit a junkyard and get a whole new gauge instead....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-20-2012, 03:17 PM   #3
BamaDave
Re: Gauge needles
how do you get the needles off?
BamaDave is offline   Reply With Quote
Old 10-20-2012, 05:28 PM   #4
Ski-me
Ski-me's Avatar
Re: Gauge needles
I have had success taking the speedometer needle off by using my two fingers and placing even, upward pressure so that the needle comes straight off. I don't know about the other gauges but after watching a speedo shop do it, I was then comfortable doing it.
Go to a junkyard and pull one to do a test. If it breaks, at least it happened in the junkyard vs. your own gauge.....
- Jeff
Old 10-20-2012, 09:10 PM   #5
cfan10
cfan10's Avatar
Re: Gauge needles
Forks just slide it under apply a little side to side pressure, it pops right off.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 10-20-2012, 10:40 PM   #6
trivon56
trivon56's Avatar
Re: Gauge needles
I wasn't lucky enough to get needles that stayed while once I popped them off. So inwas curious if other car model needles will work b
Old 10-24-2012, 05:35 AM   #7
wraprail
wraprail's Avatar
Re: Gauge needles
I changed my speedo and tach to a early 70 camaro and changed all the other needles to match. Just pull um off and push um on. I would guess most 70s-80s GM guage needles will interchange
wraprail is offline   Reply With Quote
Old 10-24-2012, 10:41 AM   #8
Ski-me
Ski-me's Avatar
Re: Gauge needles
If it's the speedo, the hardest part is trying to get the needle back in the same location. I did a lot of trial and error with a gps before I got in the correct spot again.
- Jeff
Old 10-24-2012, 10:48 AM   #9
trivon56
trivon56's Avatar
Re: Gauge needles
Are there certain needles that will fit. I purchased a gauge set from eBay as parts but once I took the needles off that set it didn't match my gauges connection. My gauges have a metal piece that come up and my needles are hollow. The gauge set that i got from eBay the needles have a metal piece coming out and the gauges are hollow. Can someone assist me on this.
Old 10-25-2012, 12:47 PM   #10
wraprail
wraprail's Avatar
Re: Gauge needles
Old 10-25-2012, 01:30 PM   #11
trivon56
trivon56's Avatar
Re: Gauge needles
This is my gauge cluster I am trying to work on. Yeah came out ok besides the fact I can't find needles to go on it.
Old 10-25-2012, 01:44 PM   #12
earnhardtgm3
earnhardtgm3's Avatar
Smile Re: Gauge needles
Give Daniel Burns a call at:
http://gaugemarks.com/
http://gaugemarks.com/gauge_marks_005.htm
1977 Chevrolet Scottsdale:
1979 Camaro Z2/8
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 10-25-2012, 02:12 PM   #13
trivon56
trivon56's Avatar
Re: Gauge needles
Well I called that company and the guy says he does not work on trucks. Thanks for the information though.
Old 10-25-2012, 03:30 PM   #14
earnhardtgm3
This is another company I have used.
http://www.tachman.com/list.htm
http://www.tachman.com/index.htm
1979 Camaro Z2/8
