12-25-2004, 08:49 PM | #1 |
go cyclones
aluminum water pump
are there any aluminum water pumps that came stock on engines with the serpentine belt? If not will this one from GM work better?
if not will this one 12497986 — Pump, Water “Aluminum Long Leg Serpentine” This is an aluminum long leg design water pump. It can be used on all “Gen 1” 1995-2002 small-block V8 or V6 engines when using a serpentine belt system. Cannot be used on LT1 or LS1 design engines. or This one http://paceparts.com/index.asp?PageA...D&ProdID=23727 work? thanks |
12-26-2004, 01:58 AM | #2 |
hehehe, want a needle in a haystack, the GMC Syclone and Typhoon came with aluminimum water pumps on them, and they were serpentine. (4.3l v-6). Good luck finding one of those.
