07-27-2011, 12:09 PM | #1 |
1968 c10 5 on 5 Rear drum availability
Hey guys, I am in need of some assistance with rear drums on a 1968 c10. I have taken my original axle shafts and drilled them for 5 on 5 lugs. All is reassembled except I need to source drums to use with this conversion. The axle shafts have a larger center diameter protrusion on my 68 axles than the 71 and newer 11" x 2" drums with 5 on 5 used.
Are there drums available that will work for the 5 on 5 conversion on the rear with the original brake setup on a 1968 with a 12 bolt? Thanks for your responses. John
Built Not Bought 68 Fleetside C10, 68 SS Camaro, 76 Bronco Sport Custom, 60 Cadi - Bagged, 54 Olds Rocket 88, |
07-27-2011, 12:17 PM | #2 |
67-72 parts collector,…
Re: 1968 c10 5 on 5 Rear drum availability
You need 71-72 drums,... but the center hub of your axles has to be turned down to match.
07-27-2011, 12:37 PM | #3 |
Brilliant. Why the I didn't think of that I don't know. I will turn them down.
Thanks for the help. Cheers, John
09-03-2011, 11:07 AM | #4 |
Worked great, thanks again. Drilled out the 6 lug for 5 on 5 and turned the pilot down.
For others of you doing this, one of the 6 lug holes had to be plugged with a screw in plug because one of the 5 pneumonia 5 lug hopes was too close to it. it worked out very well though. Thanks, John Posted via Mobile Device
