Old 09-04-2013, 10:10 PM   #1
mlevario99
Exclamation 20 x 10 show wheels streeter
I bought a ser of show wheels streeter, 20x8.5 for the front and 20x10 for the rear. I try them today without tires and the rear wheels appear that they will rub the tire against the fenders. The truck is a 66 step side, if I remember correctly, the only modification I did to the rear was to use a drop spring, don't remember if it was 1" drop or 2". Who has use 20" x 10" wheels on the rear without any problems. It appears that I will have to return the rear wheels and order another 2 - 20x8.5.
mlevario99 is offline   Reply With Quote
Old 09-04-2013, 10:28 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: 20 x 10 show wheels streeter
What is the backspacing on the rear wheels? If you order the same wheels with MORE backspacing then they will tuck inside the rear fender more and you might be able to use a 10" wheel.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-04-2013, 10:31 PM   #3
mlevario99
The offset is 0, actually when I measure the wheel in the truck, it appears that the wheel is center inside the fender, so I believe the tire will rub the fender and the bed.. If anyone has use this setup any help please, otherwise I'm returning the wheels tomorrow.
