03-03-2010, 12:42 AM | #1 |
Junior Member
Will a 292 harmonic balancer fit a 250 motor?
1970 1/2 ton swb |
03-03-2010, 07:25 PM | #2 |
Re: Will a 292 harmonic balancer fit a 250 motor?
No.
03-03-2010, 08:51 PM | #3 |
Junior Member
does the 292 harmonic balancer fit to loose?
1970 1/2 ton swb |
03-04-2010, 07:19 AM | #4 |
It might fit better than a 250 HB on a 292. The 292 harmonic balancer has 2 or 3 grooves for fanbelts. It is heavier than the 250 HB. The larger mass makes for smoother operation. 292 cranks are tapped on the front end for a securing bolt and have a 1.255" O.D. snout diameter, same as an SBC. Most 250s aren't tapped on the crank snout end.
The OEM p/n for the 292 damper is 10141202 for the 3-sheave with a hot-bonded outer ring.
